question on jdm/ukdm itr fogs
Old Dec 16, 2012 | 07:19 PM
vtacyo's Avatar
Default question on jdm/ukdm itr fogs
Ive been digging alot lately and found that the ukdm foglights itself,not including the surrounding and the jdm foglights look the same but when i try to compare oem part numbers i cant get anything. The loom, switch etc all look the same minus the surrounding for the bumper...can anyone weigh in on this and let me know if they are the same or not?
Old Dec 16, 2012 | 07:34 PM
BlueIntegraBoy's Avatar
Default Re: question on jdm/ukdm itr fogs
The lenses are probably the same with different housings. And I believe you are referring to the optional pre-facelift foglights.
Old Dec 17, 2012 | 04:23 AM
94rs-turbo's Avatar
assuming your refering to 94-97 front style fogs, yes lens look same to me along with a lot of other hondas. Brackets will be different for sure, harness wouold work/be the same
Old Dec 17, 2012 | 05:30 AM
vtacyo's Avatar
No my integra is the 98-01. I was looking to buy the Ukdm but the people in uk think its gold when its not. I was just going to do some modifications to make it Ukdm.
Old Dec 17, 2012 | 09:45 AM
R boy fresh's Avatar
Do what to make it UKDM ?, The Stanley 94-97 fog lights are the same shape,size & dimensions and the brackets bolt up the same to the foglights (4 screw configuration) the lense is usually a different color (yellow instead of clear) ,you would need the ukdm brackets & shrouds to locate them in the UkDM location which is now mostly if not all discontinued last i checked. The 98-01 usdm optional fogs are totally different if thats what your refering to. those are compatible w/ 99-00 EM1 Si fogs... I had/have them all so speaking from experience...
Old Dec 17, 2012 | 12:40 PM
vtacyo's Avatar
I have a 99 integra bumper. I know the Ukdm and usdm bumper are the same. I've talked to a couple people in the UK to get the front fogs but only one has them and wants entirely too much. So I got to searching more and saw a guy with jdm fogs for an integra. The fogs, loom and switch look the same but of course the shroud is different. I guess what I'm getting at is the guy with the jdm fogs has everything for 200 and if its all the same minus the bracket and shroud for bumper then all I would need to get from the UK would be just bracket and shroud as the jdm guy has everything else. So my question is, is the jdm integra fogs this guy has the exact same oem part number as that of the Ukdm?
Old Dec 17, 2012 | 12:41 PM
vtacyo's Avatar
If you have a email I could send pictures of what I'm saying exactly.
Old Dec 17, 2012 | 01:54 PM
justjdm's Avatar
No, the foglights are different. The 94-97 JDM/USDM foglights have fins on the back of the shrouds and the UKDM ones are smooth. You'll have to grind down the fins in order for them to fit into the UKDM brackets and your gonna have to piece the UKDM bracket together with the USDM/JDM ones to make them align up with the UKDM shrouds. The wiring harness and switch is all the same as well as the plugs/pigtails though.
Old Dec 17, 2012 | 09:25 PM
vtacyo's Avatar
yea i can see that now....hopefully i can get a set soon
Old Dec 18, 2012 | 06:06 AM
Lro255's Avatar
Most 90's OEM fogs will fit the UKDM Bracket. I own 3 complete sets of UKDM fogs and many others. From my current collection I know for a fact that 94-97 sir, Prelude ba8 and UKDM use the same fogs under different part #'s. Even the fake ebay SIR fogs will fit the uk bracket perfectly.
Truthfully I really don't see you saving much by purchasing the jdm version. The uk bracket and shrouds are the most expensive and hardest parts to find.
Old Dec 18, 2012 | 11:06 AM
vtacyo's Avatar
you should sell me your uk fogs then? lol
EG-tofu
33
Aug 19, 2006 12:26 AM
xunkn0vvnx
Jul 18, 2005 08:49 AM
xunkn0vvnx
May 25, 2005 05:43 PM
DC2*Integra
Apr 14, 2004 02:29 PM
Benjamin Tang
Mar 14, 2002 07:10 AM
