advice:del sol failed smog test
Old Dec 16, 2012 | 02:53 PM
quiambao1180's Avatar
Default advice:del sol failed smog test
MAX CO% IS 0.55 & mines was a 0.61
1994 honda del sol
most people I ask say its the Cat, but I wanted some other opinions before I shell out the money for a new cat. Any help would be appricated
Thanks in advance
Old Dec 16, 2012 | 02:55 PM
Jdmjc's Avatar
Default Re: advice:del sol failed smog test
as long as you have no check engine light then most likely its your cat
Old Dec 16, 2012 | 03:01 PM
yeah no CEL, Thanks
Old Dec 16, 2012 | 03:39 PM
B20DelSol's Avatar
Well...is the rest of the ignition and fuel system in good operating condition as well?
I mean, it is not going to make a huge difference, but make sure your plugs, wires, dist. cap and rotor, pcv valve, air filter, and fuel filter are good are new. You can also make sure your ignition timing is within spec.
Just some other things to look at, but, at 18 years old...it could be the cat.
Old Dec 16, 2012 | 04:07 PM
ekb16's Avatar
CO2 tells you how your cat converter is working. anything 14+% means your cat is working like it should. i would look into a o2 sensor and maybe doing a valve adjustment
Chevrille
19
Jun 3, 2013 03:52 PM
LAO
Jul 28, 2008 07:00 AM
racerus
Apr 24, 2006 01:13 AM
GsR-Freak
Apr 3, 2005 11:40 PM
Splangtastic
Jun 19, 2003 01:30 PM
