2000 si ecu doesn't have power
Old Dec 16, 2012 | 12:42 PM
fakieSI's Avatar
Default 2000 si ecu doesn't have power
I have a 2000 civic si and it would keep losing it's memory and would not allow me to pass emissions. Now it doesnt power up at all. Any ideas?
Old Dec 16, 2012 | 04:47 PM
RT_NEWYORK's Avatar
Default Re: 2000 si ecu doesn't have power
Battery?
Old Dec 16, 2012 | 07:47 PM
fakieSI's Avatar
battery is fine... has good voltage... Was noticing while trying to diagnose this thing that the power going into the main relay is 12.4v but as soon as the key is turned on it drops into the 2.2-2.8v range... 148 views and only 1 reply???? Come on guys lol...
Old Dec 16, 2012 | 07:55 PM
go-part's Avatar
Do ll the other electrical parts on your car work?
When was the last time you had your alternator replaced?
Old Dec 17, 2012 | 06:45 AM
fakieSI's Avatar
All the other electronics work. They cars starter doesn't work now. Every time I try to start it now the fan kicks on lol.
Old Dec 17, 2012 | 04:12 PM
beecee18's Avatar
Battery or compromised connection/ground/wiring.
Old Dec 18, 2012 | 09:21 AM
fakieSI's Avatar
So bad grounding to the battery or in the harness you think?
Old Dec 18, 2012 | 10:11 AM
egcoupe918's Avatar
could be the battery ground how does the cable look? corroded?? I had that problem in one of my nissans replaced batyery ground and fired right up
Posted from Honda-tech.com App for Android
Old Dec 18, 2012 | 04:04 PM
fakieSI's Avatar
The battery ground is a zero gauge wire ran straight to the chassis all new.
Old Dec 18, 2012 | 05:07 PM
Former User's Avatar
Does the main relay plug get battery voltage from both hood fuse 44 (6) and dash fuse 13 (7)?
Old Dec 19, 2012 | 06:38 AM
fakieSI's Avatar
I will check that today when I get home.
k-rizz
Nov 5, 2012 06:12 PM
1904wrencher
Feb 10, 2010 03:04 PM
nebrown1
Acura TL, RL & ZDX
Oct 18, 2009 01:04 PM
liquidx
Aug 15, 2009 05:37 PM
HatchBox
Oct 24, 2003 06:10 AM
