overheating
Old Dec 16, 2012 | 11:35 AM
mikeryan161's Avatar
Default overheating
so my car started to overheat today on the way home I turned on the heat and it brought the car back to normal temp till I got home. Their was no steam so I am going to assume their is no leak the overflow was empty though so any ideas of what it could be.
Old Dec 16, 2012 | 01:59 PM
Ryan96GSR's Avatar
Default Re: overheating
if the overflow tank is empty that is a sign you are likely low on coolant. check it once the car cools down. Then move From there
Old Dec 16, 2012 | 02:04 PM
grumblemarc's Avatar
The Grumpiest
Headgasket.
Old Dec 16, 2012 | 03:32 PM
Patryk_98's Avatar
Originally Posted by grumblemarc
Headgasket.
Way to jump to conclusions O.o
I remember when my car was over heating I replaced the thermostat and flushed the old coolant added new coolant and I was golden.
Old Dec 16, 2012 | 03:36 PM
The Grumpiest
If he's not leaking it then he's burning it. Only one of two ways to do that. Headgasket or crack in the block. He pretty much said it isn't leaking. If it's something ridiculous like he failed to top off the fluids then that's another thing entirely. Cross your fingers and hope it's just a bad thermostat but these cars are old and headgaskets are failing like they were taking the SATs.
klewis50
Jul 2, 2013 09:55 PM
ziptie
Jul 24, 2007 11:48 AM
BubLBack
Oct 5, 2006 09:47 PM
SOHC_MShue
Apr 16, 2005 02:42 PM
dustin
Jul 21, 2001 12:34 PM
