Suspension gurus wanted
Old Dec 16, 2012 | 11:03 AM
Skids1's Avatar
Default Suspension gurus wanted
im looking to change the suspension in my itr im currently running stock and wanna get some opinions on peoples preferences and general thoughts. looking for something not too stiff that i can still daily on but that would be a decent track setup also. been considering koni yellows but not sure if i wanna do a strut setup like that or go with a coilover. toss me some feedback
Old Dec 16, 2012 | 12:21 PM
itr#1334's Avatar
Default Re: Suspension gurus wanted
This has been covered a billion times over. Use the search function.
Old Dec 17, 2012 | 09:38 AM
Just a n00b's Avatar
Accident Prone
Koni/GC.
If you're a bauler, spring for the Moton 3-way ($7.2k)
Old Dec 19, 2012 | 01:35 PM
coolhandluke's Avatar
If you are looking into a solid DD setup that will handle track events well, the OEM suspension is actually quite capable and easy on the neck/back to DD on. I would consider replacing your current suspension if it is tired with a low miles OEM setup.
Old Dec 19, 2012 | 03:58 PM
Dave_B's Avatar
Where do you live and how are the roads in your area?
Is this your DD? Or just a weekend, fair weather car? How much track time will the car actually see?
Also, what tires are you using on the street? On the Track? What sway bars do you currently run? Do you have plans down the road to change those too?
Old Dec 19, 2012 | 04:01 PM
racebum's Avatar
konis aren't struts, the R doesn't use struts. the coilover vs conventional debate is 100% cosmetics. tein for example tack welds a collar over a shock. that's the koni gc setup with a tack weld
the koni sports are the best shock for the dollar made. you can try those with your stock springs for a mild improvement and more in control ride. you also can upgrade to the koni specific ground controls if you want more spring rate.
keep in mind the sport springs do not use progressive rates. that means while easier to control they are more harsh.
spring rate is a big driver preference thing. buy the shocks first, go from there
Old Dec 23, 2012 | 02:33 AM
CW-ITR's Avatar
Originally Posted by Skids1
..........not too stiff that i can still daily on but that would be a decent track setup..........
IMO, there is no one set of suspension that can satisfies these two condition. For me, I'm using a set of H&R race springs on stock ITR shocks for the past 15K miles and It satisfies my needs as DD and autoxing. The stock shocks absorb most of rough North Bay roads and the stiff H&R race springs keep the caR horizontal in the turns at autoxing. How much did I spent? $120 for the set of used H&R race springs shipped
Old Dec 23, 2012 | 02:40 AM
kevinthefawker's Avatar
this is what i did. bought koni shocks paired it up with the stock itr springs, handled and rode perfect. but was way to soft for track use for my needs. so i ended up ordering the ground control setup for it and been a lot happier so far. and spring rate is a very very big driver preference.
tamparican
Suspension & Brakes
Mar 21, 2013 06:25 PM
R.A.T.
Apr 29, 2010 04:52 PM
ALLMOT0REJ1
Suspension & Brakes
18
Oct 31, 2009 06:51 PM
CRXBart
71
Jun 18, 2009 12:38 PM
B18c5__Owns
Apr 10, 2006 07:06 PM
