Help PLS- Misfire No 1 & 2 Cylinder
Old Dec 16, 2012 | 09:26 AM
Moto101's Avatar
Default Help PLS- Misfire No 1 & 2 Cylinder
My H23A1 engine runs great at idle but when it warms up Cylinder number 1 & 2 misfire. Compression is ok 180 psi in 3 cylinders and 175 in the other.
ANy ideas?
Old Dec 16, 2012 | 10:55 AM
snobordboy's Avatar
Moderator
Default Re: Help PLS- Misfire No 1 & 2 Cylinder
Pretty generic things to check are your spark plugs, plug wires, cap and rotor, and fuel injectors.
Old Dec 16, 2012 | 11:24 AM
98vtec's Avatar
moderator emeritus
take the plugs out and inspect them. If those check out ok, remove distributor cap and check for corrosion on the rotor and cap points.
Also, when is the last time a valve adjustment was done?
there are all sorts of reasons why a cylinder will misfire. Either take it upon yourself to do a little digging or take it to someone who knows diagnostic.
Old Dec 16, 2012 | 03:37 PM
Moto101's Avatar
I installed new plus, distributor cap, and rotor button. It runs great when its cold but as soon as it warms up its starts skipping. Cleaned the EGR, and check ed the IAC.
Old Dec 18, 2012 | 06:04 PM
Moto101's Avatar
Problem solved. I ran some top engine cleaner through the brake booster vacuum line and cleaned out the IAC. Running great now. Intake was really gummed up.
Old Dec 18, 2012 | 06:24 PM
civicguy167's Avatar
if problem comes back check plug gap, always use oem spec plugs ( i prefer bosch) and replace wires.
hondalord
May 27, 2010 08:42 PM
jdmsleeper12
Jul 27, 2009 10:54 PM
JDM92da6
May 4, 2009 10:48 PM
benjaminenjamin
Aug 1, 2006 04:30 PM
VvPeachyvV
Jun 6, 2006 12:49 PM
