missfire???!!! Need help
Old May 4, 2009 | 07:32 PM
JDM92da6's Avatar
Default missfire???!!! Need help
Ok so my 98 Integra ls at idle shakes like crazy,and the check engine light calls miss fire, so I noticed cyl #1 does nothing when I pull the spark plug wire out our when I pull the injector off, so then I change the plugs and injector , still the same thing, but when I drive the car it feels fine... Any idea wat it could be??? Thanks
Old May 4, 2009 | 08:11 PM
b-series-em1's Avatar
Default Re: missfire???!!! Need help
check fuel all fuel injectors and motor mounts
Old May 4, 2009 | 08:22 PM
supracrx's Avatar
so which cylinder did the Check engine light say? was it multiple or only the single#1 cyclinder? if it was multiple i would suggest check the distributor or cap and rotor.
Old May 4, 2009 | 10:48 PM
TeaAddict's Avatar
if you have never replaced your distributor cap and rotor then i would think that it is time. also it could be your spark plugs or wires.
Nick Cronk
Apr 20, 2013 06:14 PM
Moto101
Dec 18, 2012 06:24 PM
jdmsleeper12
Jul 27, 2009 10:54 PM
Downz
Feb 11, 2007 06:52 PM
XtremeCarTuner
Jul 10, 2003 07:48 PM
