1989 Honda Accord LX problems
Old Dec 15, 2012 | 09:18 PM
Karhoot's Avatar
Default 1989 Honda Accord LX problems
Hello, and I'm welcoming myself to this wonderful forum :-)
I am having a few troubles with my Honda I just picked up. I'm getting minor left and right movement in my steering wheel while trying to keep it straight. I don't know what it could possibly be.
Also, when idling, my car feels like it wants to stall out. It sputters really bad while sitting in first gear and the clutch fully depressed.
Any diags?
2.0L, 5 speed trans, A20a1
Old Dec 16, 2012 | 05:23 AM
Crx_owner_20's Avatar
Default Re: 1989 Honda Accord LX problems
Possiable outer tie rod or inner tie rod ends. Or your power steering rack itself.
As far as idling it could many diffrent things... it could be a fuel issuie, air issuie, dont realy know without looking at it.
Old Dec 16, 2012 | 01:38 PM
Karhoot's Avatar
I let my buddy take a quick peek at it earlier, and he told me it's 90% the distributor cap and rotor. Is there a way of testing this to make sure they're bad? And would that cause rough idling, as well as near stalling of my engine? Today, I went to the gas station, and all I could hear was it sputtering as it was running out of gas, but I had a full tank
Do you think the dist. cap & rotor is the culprit?
Old Dec 16, 2012 | 01:53 PM
grumblemarc's Avatar
The Grumpiest
Why don't you change it and find out? I'm betting it's never been touched since you've owned the car. I'm also going to go out on a limb and guess it hasn't had a full tune up in a long while.
Old Dec 17, 2012 | 11:10 AM
Karhoot's Avatar
And you are correct. xD
Actually, I popped my hood and found the plug wires were misplaced on the dizzy cap.
If I'm not mistaken, looking at the engine, it's 1-2-3-4? Correct? Numbers meaning cylinder/piston number.
I took off the cap and checked the rotor, they both look pretty damned new.
Old Dec 18, 2012 | 07:07 PM
danny_ca5's Avatar
The rotor and cap are cheap just replace them. make sure you put the rotor on RIGHT so many people put them on the wrong direction because theres nothing that prevents you from doing so. The A20A1 is carburated so vacuum leak is more than likely the issue your having as far as idling funny.
If youre standing in front of the car and looking at the engine the cylinders go 4-3-2-1
and the new cap should have tiny marks where the wire boots go that indicate which wire goes where. for example I for wire from cylinder 1. II for wire from cylinder 2. III for wire from cylinder 3. Lastly, IIII for the wire coming from cylinder 4.
Old Dec 18, 2012 | 07:09 PM
danny_ca5's Avatar
Also, it doesnt hurt if you replace the wires with OEM wires as well. Yes theyre expensive if you can find them at your local dealer but they will outperform anything you can find from your local auto parts store
Old Dec 19, 2012 | 11:58 AM
Karhoot's Avatar
Okay I did that, and it's still idling funny. I did infact, take a video on my cellphone of the sound. It's sputtering when my heat is on.
Usually when it's sitting there, it'll sputter, like a misfire, but I don't think it's misfiring. It's so weird. ;O
Bogging down, almost stalling, then raising RPM
Old Dec 19, 2012 | 01:41 PM
The Grumpiest
Test the TPS.
nicus felicien
Mar 2, 2015 05:12 AM
jsbenami
Jun 24, 2012 09:06 AM
SIRCOOKS
10
Oct 10, 2011 06:52 AM
mkrieger500
Oct 25, 2008 04:31 PM
mrssheeps
Jul 21, 2002 06:56 AM
