89 Crx ground up, lots of boost build!
Old Dec 15, 2012 | 03:19 PM
Crx_owner_20's Avatar
Default 89 Crx ground up, lots of boost build!
So I've owned many honda's, expecially crx's. I've kept my eye out on the certain crx with no accidents. Test driving a customers car at work down some side streets and there she sat.. Waiting for me to buy her. Offered 400.00 for her, and the owner said 800.00. Long story short I still got it for 400.00. So follow along, hopefully you enjoy the build!
CURRENT STATE:
Arrival at the shop, removed fenders, hood, windshield.
Stripped her down nothing, removed rear quarter glass, all of interior, motor, trans, harness, dash. Everything, and moved her into the body shop
Roof has some dents...
Shaved the intenna..
Few more dents.
Sand Blasted the engine bay, I'm going to Fab. a plate to covor the firewall, weld up all the seems, holes, I want a shaved engine bay. One of a kind.
Old Dec 15, 2012 | 03:27 PM
Default Re: 89 Crx ground up, lots of boost build!
Primer
Guide Coat..
Primered the rear bumper, plan on using Exospeed or strada front fenders and bumper.
Removed all trim glass and layed a fresh coat of primer. I have all new OEM honda trim for the rear hatch.
Doors are stripped and a coat of primer, blocked, guide coated and wet sanded..
Old Dec 15, 2012 | 03:36 PM
So the hood ended up having a few dents... haha dang it!
A little bit of glazing puddy, primer filler, block sanding, guide coat, wet sand and she is ready for paint.
Old Dec 15, 2012 | 04:46 PM
A few Things I've collected.
Gsr head, skunk2 valves, supertech guides, supertech keepers, omni power retainers, skunk2 pro2 cams with skunk2 cam gears, Ported.
Got a rywire harness.. Of course before they started selling them dirt cheap : (
Hasport shift linkage...
And course the tools that make it happen!
Old Dec 16, 2012 | 04:21 AM
Stay tuned! More to come!!
Old Dec 16, 2012 | 04:35 PM
shogun86's Avatar
Build looks like it's off to a great start. Can't wait to see the finished product.
Old Dec 17, 2012 | 10:45 AM
Thanks! I work everyday so the only time I have with her is after work, so more updates later tonight!!
Old Dec 17, 2012 | 04:47 PM
Shaving the engine bay, welding up all the un-usefull holes and shaving the firewall.
Old Jan 7, 2013 | 01:07 PM
LiAngeL8967's Avatar
this is a very interesting thread no more UPDATES?????
Old Jan 21, 2013 | 01:34 PM
So I had to lay some primer down to keep everything from rusting. But I pulled the cross member, I have to re-inforce it to keep it from bending in half where the motor mount sits. Anyone have any idea's?
Some more grinding to do and some puddy but its looking better!
Old Jan 21, 2013 | 04:44 PM
maxwellmercer's Avatar
Interested to see where this ends up.
Old Jan 21, 2013 | 05:44 PM
HOMEMADEPOWER's Avatar
Love the progress.Keep it up the good work.
Old Jan 22, 2013 | 03:48 PM
Thanks!! I'm going to work on the engine bay some more this weekend. Crazy amount of work and time already spent on just the bay. But its worth it all to me, thanks for the support!
Old Jan 24, 2013 | 05:58 PM
I have some new updates, got some more of the firewall plate up.
Old Jan 24, 2013 | 10:19 PM
whitesihatch's Avatar
firewall plate looks good, however ive seen people cut a large section of the firewall out and weld in a flat sheet like your cover plate, thus creating a newer flatter portion of the firewall. Just my .02 so you dont have to worry about mount issues or intake clearence. great build thus far
Old Jan 27, 2013 | 06:55 AM
Ive already mocked up the mount, no issuies there. As well as my intake, still clears about a inch. Yea, lots of ways it can be done, still turned out good.
Old Jan 27, 2013 | 07:02 AM
Nate13's Avatar
Hopefully you left a little room between the firewall and the plate you welded on, it might rub and squeak if not. If they're touching you could drill holes in the new plate and plug weld them together. Just a my 2cents. Nice progress!
Old Jan 27, 2013 | 09:34 AM
Yea that crossed my mind as well. But it's welded solid to the firewall, it has to vibrate to make a noise. And I'm also going to fill the space with something, haven't decided as to what yet. Maybe a foam or something followed by some dynomat to help get rid of road noise.
Old Jan 27, 2013 | 10:03 AM
00siboy's Avatar
I like where this is goin.
Old Feb 14, 2013 | 05:25 PM
Finished the firewall plate as far as welding. I laid down some puddy so I can make it even. After I sand everything down and lay some primer it will look great! Here is the progress so far, slow and steady.
And I decided to remove the old sound deadening material. I didn't use dry ice like ive seen done. I used my rubber mallet and it all broke up. I guess because its so old. Took 5 min.
Old Feb 15, 2013 | 03:54 PM
00siboy's Avatar
Nice updates. :thumbs up:
Old Feb 16, 2013 | 03:47 PM
Going to work on her some more tom. Pictures will be up after that!
Old Feb 17, 2013 | 02:15 PM
The DA helped me straighten out the plate pretty quick, well where it could get too.. The rest is left for me to do by hand.
Old Feb 19, 2013 | 05:41 PM
00siboy's Avatar
So whats the point of the firewall mod?
Old Feb 19, 2013 | 06:47 PM
I want a clean Engine bay, notice there is no seams or holes anywhere else? I mean its not a need. I just wanted to do something diffrent.
