88crx si GSR swap WIRING ISSUES HELP!!!
Old Dec 15, 2012 | 12:20 PM
CrooKz88CrxSi's Avatar
Icon2 88crx si GSR swap WIRING ISSUES HELP!!!
doing a obd1 gsr swap into my 88crx. bought the swap from hmotors and a factory si engine harness for the swap but now it seems my harnesses dont match up. can some1 help me identify my problem? i think hmotors sent me the wrong harness. is there any1 whos rele good with honda harnesses that can identify my harness? any help would b greatly appreciated!!
Old Dec 15, 2012 | 12:23 PM
Default Re: 88crx si GSR swap WIRING ISSUES HELP!!!
first pic is on the passenger side shock/strut tower second pic is driver side shock/sturut tower. can any1 identify what these plugs go to or at least tell me what 2 harnesses i have if mine dont match?
Old Dec 15, 2012 | 12:27 PM
hers how it looks installed
Old Dec 15, 2012 | 05:30 PM
EF8DayDreamer's Avatar
the green plug drivers side shock tower is to a resistor box but thats for a obd0 fuel injectors. your swap has obd 1 fuel injectors. so you have to remove the green plug or switch to obd0 injectors. if you decide to go obd0 later on dont cut and splice but to go ahead and stay obd1 you have to take the green clip out using a pick (theres a plastic clip inside each slot for those clips, flick it up or down dont remember which. you can either cut and splice the metal clips on the red and black wires and twist them together or find a copper wire and wrap them in place for a temporary fix until you figure something out.) the clear clip drivers side not sure what its for but i know theres supposed to be a male end there. if you have a base model crx i think thats the problem and you may have a integra da wire harness there. btw clean engine you have there. hnmotors is awsome.
Gumbygrom
May 13, 2018 10:28 PM
white90rexsi
Jun 22, 2007 06:21 PM
totoshatch
Jun 11, 2007 04:03 AM
solohatch
Jul 1, 2005 12:13 AM
