Bolt on 750+hp capable fuel system
Means of contact: PM or text 540-270-9843
Price: $800 or will separate
Description: Changing the fuel system on my car for next year since I'm switching to C85 and going with a single pump setup. For sale I have ID1000's (k-series injectors with B-Series top hats), Bosch 044 pump with all fittings and line (-6) from factory fuel filter to fuel rail, even have the fitting for the fuel rail and the special fitting for the factory filter housing. Also comes with a 5 pass old, Walbro 400 in-tank pump (badass dual chamber pump, wish I could keep it). I'll even include the housing for the in-tank pump so you don't have to mess with it. If you do buy this stuff, please wire it correctly, with relays, and not like a jackass, I don't want to see my stuff burned up due to bad wiring. Please, someone put this to good use. My car made 720 to the tires with a 255 in-tank and we cranked the boost a bunch after the 400 so this setup works great, probably more around 800hp. Only trades are for ID2000's or a Magnafuel Pro Tuner 750.
BLKCRX
Sep 8, 2003 04:33 PM
