Transmission & Drivetrain Gearboxes, Differentials, Clutches
casing not closing (pics)
Old Dec 13, 2012 | 03:53 PM
oldskooldan's K's Avatar
Default casing not closing (pics)
so i have a gsr casing that wont close. i took out the gears and it would close with out em. here are some pics...
sorry for the pig pics
Old Dec 13, 2012 | 05:18 PM
Rosko's Avatar
Default Re: casing not closing (pics)
Do you have it sitting flat on a table by chance and its just pushing the input shaft upwards? I always use a couple 2x4's underneath it to hold keep pressure off the shaft. If the input shaft is sitting on the table then its holding up the entire assembly.
Old Dec 13, 2012 | 09:20 PM
No the mainshaft is sittin freely. I made a whole so the main shaft could go in it.
Weird thing is I installed a set of type r gears and the freaking trans sits freely!! Wtf??
Old Dec 13, 2012 | 09:21 PM
I know it has something to do with the counter shaft because I only put the mainshaft in there with out the counter and it sits flush??
Old Dec 13, 2012 | 09:43 PM
Left is type r
Right is gsr..
Old Dec 14, 2012 | 09:05 AM
raene's Avatar
Have you checked the shims?
Old Dec 14, 2012 | 01:30 PM
Yes I have tried 2 shims and 1 and even with none.
Old Dec 16, 2012 | 04:49 AM
Aquafina's Avatar
There are no shims for the countershaft. Do you have the snap ring fully open before trying to seat the case? It isn't open at all in the first pic. Cases like to hang up on the shift piece shaft (shaft that goes through the SCHA).
Old Dec 16, 2012 | 11:27 AM
David @ Synchrotech's Avatar
Check your countershaft - it looks like you are installing LS gear stacks with an ITR ring gear.
__________________
Old Dec 16, 2012 | 11:43 PM
Thanks synchro tech I'll look at them in the morning!!
xtremvw
Jul 23, 2009 11:00 AM
c1v1c98
Apr 29, 2007 11:55 AM
KaoticSnow
Aug 4, 2004 07:54 PM
FnkyChnkyMnky
Sep 17, 2002 10:01 PM
