D4 flashing on a 92 wagon
Old Dec 13, 2012 | 07:18 AM
bigblock 67's Avatar
Default D4 flashing on a 92 wagon
Why is D4 flashing continous? Replaced several resisters solving a no shift problem. Is there a lock up gear in D4? It shifts into high gear but thought there was an overdrive. Thanks
Don
Old Dec 13, 2012 | 09:48 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: D4 flashing on a 92 wagon
The H4A has OD in 4th gear, lockup can feel like a gear sometimes.
What code(s) did you get with the blinking D4?
Click on the troubleshooting link in my sig.
Old Dec 14, 2012 | 08:20 AM
Hi, The D4 will not stop flashing. I quit counting at 130. There is no lockup in 4th. I pulled neg cable for hours...no change. Thanks for input
Don
Old Dec 14, 2012 | 08:52 AM
92 civic ex 4dr's Avatar
How dose the car shift? Dose it shift rough or slip and when your lets say on the freeway Arty around 2,500 to 3,000 rpm the torque converter lock solenoid should lock up and you will feel it kind of like a fifth gear and the rpm's will drop slightly.
Old Dec 14, 2012 | 09:03 AM
It shifts normal , Just wont shift up in D4. May be a solonoid?
Thanks for note
Don
Old Dec 14, 2012 | 09:15 AM
It is possible it's the solenoid. Could also be the gasket for it could be plugged. The gasket for those also doubles as a screen filter. The solenoids cost around 300.00 bucks and the gasket is 40-80 i don't remember exactly but i do know that both items are dealer only items. Junk yard man. You will be lucky though if you find the solenoids. If you do find them buy the new gaskets. I think the lock up solenoid is the lower solenoid. Not positive though.
Old Dec 14, 2012 | 09:23 AM
I did pull top solonoid and it looked ok, clean screen ; bottom looked harder to get to so I didnt pull it
I tested all 4 and bottom pair didnt click as sharp as top did. Dont know how else to check.
I will never go to a dealer for any issue.... if I can help it
Thanks again
Don
Old Dec 14, 2012 | 09:30 AM
You will have to go to the dealer to buy the part unless you but it used from a junk yard.
Old Dec 14, 2012 | 04:18 PM
MAD_MIKE's Avatar
MM Gruppe B
The way you read the code from the CEL is fairly simple. It will repeat the code until you turn off the ignition or remove the jumper.
A code 3 would be _ _ _ .
A code 30 would be ___ ___ ___.
A code 33 would be ___ ___ ___ _ _ _
The codes would be presented in numerical order from lowest count to highest.
Originally Posted by tasauto
Watch the 'S' or 'D4' light for flashes.
If no problem exists, the light won't flash. If a problem exists, the light will give you either short, or long and short flashes. Short flashes are a 'ones' digit of either a one or a two digit trouble code. Long flashes are the 'tens' digit of a two digit code. Short flashes are about a half second long, and long flashes last about a second and a half. There is about a one second 'OFF' pause between each code.
All codes will be shown in sequence, lowest number first, up to the highest number. The sequence will repeat as long as the key is on and the connector is jumped together." †
If you are not used to watching the CEL for codes then it can be tricky to pick up the pattern initially. Sometimes shifting issues are not due to an transmission issue, but an engine issue. Retrieve the code and that will aid in getting you one step closet to the problem.
Old Dec 21, 2012 | 10:34 AM
The D4 flashing I dont believe is a code. It flashes as soon as key is on. Flash appears to be short but continues with no pauses "forever" I does not stop and will not up shift into OD.
Old Dec 21, 2012 | 12:38 PM
MAD_MIKE's Avatar
MM Gruppe B
You will have to jump the blue two wire connector and turn the ignition to ON to read the codes. If the D4 is just flashing at you then it is indicating there is an issue, that will not be the code flashing. Click on the H4A troubleshooting link in my sig, it has diagnostic information for you to troubleshoot your car.
Old Dec 22, 2012 | 05:35 AM
When I had the computer out to replace R 41 & 42, I didnt see the blue wire connector. Is is under the side panel? Thanks again for your input
Don
Old Dec 22, 2012 | 10:35 AM
MAD_MIKE's Avatar
MM Gruppe B
On 90-93 Accords I believe it is under the dash by the passenger kick panel, or under the top of that kick panel.
snee
Oct 6, 2017 07:52 PM
eMpAtHy
Jan 22, 2009 10:42 AM
takeit
Sep 11, 2007 11:54 AM
