S2000 Chassis Stiffness
Can you guys comment on the chassis stiffness compared the the Integra Type R?
I know the R has body reinforements, trunk bar, 22mm rear sway bar, strut bars, but what about the S2000? Is the frame really strong?
Just curious.
Just curious.
Considering that the S2000 was designed and built later than the ITR's now "dated" setup, one would expect the chassis design to be stiffer, or at least improved in certain areas.
The DC2 platform has been replaced with the DC5, and while the DC5R is questionably faster than the DC2R (on the track), it has a significantly stronger chassis.
Even though the S2000 is supposed to be a convertible, the design of the body and chassis takes out the "shortcomings of convertibles". And if you aren't happy with the way it is stock, get the X brace.
Sorry, but your'e wrong. The underlying frame of the S2k may be stiffer but the overall chassis is much ... much .... much looser.
-Steve (who can't remember his ITR ever havig cowl shake.)
can you describe "cowl shake"?
The front section of the car moving independent of the rest is what you notice, what is happening is the car is literally twisting. This is a trait of all convertibles due to their lack of torsional rigidity. Simply put there has never been and will never be a convertible car that is stiffer than your flimsiest fixed roof vehicle, that roof all but eliminates this torsional rigidity issue.
Point being all of this is theory, until somebody has hard numbers everybody is talking out their butt. I'll take a stab becuase its fashionable around here: I've driven both the Type R and the S2000 and I firmly believe the S2000 is obviously a stiffer chassis.
Folded the hood? Never heard of anyone doing that ------ ever ---- this includes the racer R's....
The ITR and GSR however are quite different in construction so it's not really a valid comparison.
Regarding the request for numbers, you will not find them.
Measurements of torsional rigidity -- the frequency of first the torsional mode are not exactly an industry standard test. Bimmer magazine tested various BMW's a couple years back and claimed the E46 the stiffest chassis to date, edging out the M coupe (but then they tested an M coupe with the moonroof and the E46 without). If I remember correctly the E46 was somewhere around 30Hz, which is nearly double that of the M roadster.
What you will find is various Honda press propaganda wherein they claim the X-brace design has achieved torsional rigidity equaling that of many sedans. Anyone here with an engineering degree will understand that you don't chop the roof from a car and retain the same level of structural integrity. You could come very close at the cost of excessive weight gains .. but not quite.
The fold was from the strut towers pinching to the center of the car and making the hood form a U-shape with the apex as the hood latch. The paint cracked right down the middle of the hood. Pretty wierd huh? Needless to say, I let the dealership keep that car.
I'm not trying to be argumentative or anything but if either side can't back up their case then it's all just conjecture and theory. The idea that anyone with an engineering degree should understand this or that doesn't fly. Hard data, empirical proof, whatever you want to call it, should be provided.
stephen c, before you edited one of your posts you mentioned bumpsteer as a result of the chassis design? I just saw it in my e-mail notification. I wanted to point out that the bumpsteer is not due to chassis ridigity but suspension design and it does suck in the rear, simply a lack of dampening accompanied with a stiff spring will result in bump steer.
But yeah I hear you. So you were test driving it? Hahaha.
BTW - That was a 2nd Gen GS-R. I tried with a 3rd Gen GSR but the tires kept loosing traction before I could reproduce the event. I can understand why those guys install strut braces now.
There is 2 chasis stiffness when consider chassi stiffness. Torsional (twisting) and bending(flex). The S2K is suppose to be the stiffest honda has ever designed in bending, it's stiffer than the NSX and the Honda Acoord sedan, but not as stiff as the Accord sedan in trosional stiffness. The x- brace will help add to that stiffness. The X bone frame is one of the the stiffest chasis ever designed, convertable or hardtop. Remember chasis stiffness can always be achieved at the expense of weight, it's the combination of the 2, Low weight and stiffness that is impressive. The corvette convertible is also one of the stiffest chasis out there, in fact when it first came out it was stiffer than the coupe and they adapted the chasis for the coupe.
From: Somewhere in the MidWest..., The MidWest..., USA
Modal Analysis work was performed on both [different sources, however] and the ITR's trimmed body is, in fact stiffer than the S2000. In terms of static bending the BMW Z3 and Porsche Boxter are stiffer, too. The ITR is stiffer than both of those as well it should be -- it's a coupe, after all.
ITR: approximately 38 Hz
S2000: ~34 Hz
Porsche: ~33 to 35 Hz
BMW: ~33 to 34 Hz
I don't recall the static bending numbers, but both of the German cars were stiffer, but both have heavier chassis so the natural frequency, omega = square root of the quantity(static stiffness/mass)].
The Audi TT Coupe was damned close to 40 Hz...
All things being equal [they seldom are, but they are close enough for comparison, anyway] coupes will be stiffer than convertibles and the smaller the vehicle the stiffer it should be.
Also, keep in mind that the data is very difficult to analyze and is subject to interpretation so one guy's 40 Hz may be another's 33 Hz. There is also discrepancy between auto manufacturer's description of the condition of the vehicle: Body in White [no glass]; Trimmed Body [With Glass -- makes it stiffer] and I forget the terminology at Ford for all interior trim minus seats, etc.
[Modified by Chui, 6:28 AM 10/27/2002]
S2000: ~34 Hz
BMW: ~33 to 34 Hz
