Honda S2000 Honda S2000
S2000 Chassis Stiffness
Old Oct 19, 2002 | 11:31 AM
Understeer's Avatar
Default S2000 Chassis Stiffness
Can you guys comment on the chassis stiffness compared the the Integra Type R?
I know the R has body reinforements, trunk bar, 22mm rear sway bar, strut bars, but what about the S2000? Is the frame really strong?
Just curious.
Old Oct 19, 2002 | 12:05 PM
Blue-Civic-Hybrid's Avatar
Loved
Default Re: S2000 Chassis Stiffness (Understeer)
Stiffest frame...way stiffer than an R..look it up on Motortrend...stiffest frame of any production car to date.
Old Oct 19, 2002 | 04:27 PM
Ponyboy's Avatar
Painting Masterpieces
Default Re: S2000 Chassis Stiffness (stephen c (again))
Anybody got any quantifiable numbers?
Old Oct 19, 2002 | 07:31 PM
Hash Browns's Avatar
Considering that the S2000 was designed and built later than the ITR's now "dated" setup, one would expect the chassis design to be stiffer, or at least improved in certain areas.
The DC2 platform has been replaced with the DC5, and while the DC5R is questionably faster than the DC2R (on the track), it has a significantly stronger chassis.
Even though the S2000 is supposed to be a convertible, the design of the body and chassis takes out the "shortcomings of convertibles". And if you aren't happy with the way it is stock, get the X brace.
Old Oct 19, 2002 | 11:24 PM
Psst, and the way they design the underbody has a big difference in the way the car's chassis reacts.. Go 'X' design.
Old Oct 20, 2002 | 06:31 AM
Eee Pee's Avatar
Default Re: S2000 Chassis Stiffness (Hash Browns)
Isn't one of the improvements to the '03 S2000 a stiffer chassis? Wouldn't it require some serious metal to make a convertible as stiff as a coupe?
Old Oct 20, 2002 | 08:21 AM
ITR RACER's Avatar
Integra Type R is stiffer. S2000 is very stiff for a convertible.
Old Oct 20, 2002 | 07:26 PM
Loved
Default Re: S2000 Chassis Stiffness (ITR RACER)
Sorry, but the S2000 is stiffer...
Old Oct 20, 2002 | 08:07 PM
Ponyboy's Avatar
Um, does ANYONE have quantiable numbers to back their argument up?
Old Oct 20, 2002 | 09:46 PM
JustLooking's Avatar
Default Re: S2000 Chassis Stiffness (Ponyboy)
You guys are all wrong. The Hyundai Accent has the stiffest chassis out of all the car manufactured in the world.
Old Oct 20, 2002 | 09:53 PM
Razor's Avatar
Sorry, but your'e wrong. The underlying frame of the S2k may be stiffer but the overall chassis is much ... much .... much looser.
-Steve (who can't remember his ITR ever havig cowl shake.)
can you describe "cowl shake"?
Old Oct 21, 2002 | 12:29 AM
evil vapor's Avatar
Old Oct 21, 2002 | 11:32 AM
jerrypeterson's Avatar
The front section of the car moving independent of the rest is what you notice, what is happening is the car is literally twisting. This is a trait of all convertibles due to their lack of torsional rigidity. Simply put there has never been and will never be a convertible car that is stiffer than your flimsiest fixed roof vehicle, that roof all but eliminates this torsional rigidity issue.
Are you thinking when you type? Usually you are paying closer attention to what you are saying. I --> FOLDED <-- the hood of a GSR in a sharp turn I take to work every day in my S2000. Those have a roof don't they?
Point being all of this is theory, until somebody has hard numbers everybody is talking out their butt. I'll take a stab becuase its fashionable around here: I've driven both the Type R and the S2000 and I firmly believe the S2000 is obviously a stiffer chassis.
Old Oct 21, 2002 | 02:08 PM
Folded the hood? Never heard of anyone doing that ------ ever ---- this includes the racer R's....
The ITR and GSR however are quite different in construction so it's not really a valid comparison.
Regarding the request for numbers, you will not find them.
Measurements of torsional rigidity -- the frequency of first the torsional mode are not exactly an industry standard test. Bimmer magazine tested various BMW's a couple years back and claimed the E46 the stiffest chassis to date, edging out the M coupe (but then they tested an M coupe with the moonroof and the E46 without). If I remember correctly the E46 was somewhere around 30Hz, which is nearly double that of the M roadster.
What you will find is various Honda press propaganda wherein they claim the X-brace design has achieved torsional rigidity equaling that of many sedans. Anyone here with an engineering degree will understand that you don't chop the roof from a car and retain the same level of structural integrity. You could come very close at the cost of excessive weight gains .. but not quite.
It wasn't supposed to be a comparison. You stated that no convertable could have a stiffer chassis than a sedan. GSR = Sedan S2000 = Convertable.
The fold was from the strut towers pinching to the center of the car and making the hood form a U-shape with the apex as the hood latch. The paint cracked right down the middle of the hood. Pretty wierd huh? Needless to say, I let the dealership keep that car.
Old Oct 21, 2002 | 02:30 PM
Ponyboy's Avatar
Hmmm. . .I bet enterprising young minds could find it.
See, but I won't tell you, "I told you so." All you have to do now is find the Honda data.
Yeah, and I've also heard engineers also say no one would every break 100hp per cylinder. Or an electric car would never be a feasible performance car. There's lots of incidents where people have said it could never be done. . .and then it's done.
I'm not trying to be argumentative or anything but if either side can't back up their case then it's all just conjecture and theory. The idea that anyone with an engineering degree should understand this or that doesn't fly. Hard data, empirical proof, whatever you want to call it, should be provided.
Old Oct 21, 2002 | 05:54 PM
falcongsr's Avatar
What is this crap?
i shoulda figured you were a mechanical engineer.
Old Oct 21, 2002 | 06:40 PM
evil vapor's Avatar
Default Re: S2000 Chassis Stiffness (falconGSR)
stephen c, before you edited one of your posts you mentioned bumpsteer as a result of the chassis design? I just saw it in my e-mail notification. I wanted to point out that the bumpsteer is not due to chassis ridigity but suspension design and it does suck in the rear, simply a lack of dampening accompanied with a stiff spring will result in bump steer.
Old Oct 21, 2002 | 06:56 PM
But yeah I hear you. So you were test driving it? Hahaha.
Crazy thing was Lynnwood Honda let me test drive another car immidiately afterwards.
BTW - That was a 2nd Gen GS-R. I tried with a 3rd Gen GSR but the tires kept loosing traction before I could reproduce the event. I can understand why those guys install strut braces now.
Old Oct 21, 2002 | 07:32 PM
racezx9's Avatar
There is 2 chasis stiffness when consider chassi stiffness. Torsional (twisting) and bending(flex). The S2K is suppose to be the stiffest honda has ever designed in bending, it's stiffer than the NSX and the Honda Acoord sedan, but not as stiff as the Accord sedan in trosional stiffness. The x- brace will help add to that stiffness. The X bone frame is one of the the stiffest chasis ever designed, convertable or hardtop. Remember chasis stiffness can always be achieved at the expense of weight, it's the combination of the 2, Low weight and stiffness that is impressive. The corvette convertible is also one of the stiffest chasis out there, in fact when it first came out it was stiffer than the coupe and they adapted the chasis for the coupe.
Old Oct 22, 2002 | 08:02 AM
SRV's Avatar
SRV
Not stiff enough? You can put the Spoon Tower Bar, Front Lower X-Beam Bar and the Rear Lower Arm Bar to make the Chassis Stiffer.
Old Oct 22, 2002 | 01:09 PM
Default Re: S2000 Chassis Stiffness (SRV)
I think the point was that the stock chassis was enough. All the extra Spoon bling-bling probably won't do anything but slow you down.
Old Oct 23, 2002 | 04:48 PM
tinkfist's Avatar
Default Re: S2000 Chassis Stiffness (jerrypeterson)
Old Oct 23, 2002 | 04:49 PM
tinkfist's Avatar
http://www.s2ki.com/imagecatalog/cus.../image/list/3/
Old Oct 24, 2002 | 10:01 AM
Default Re: S2000 Chassis Stiffness (tinkfist)
A cut away picture of the frame from s2ki.com. I'll bite, what are you trying to show with it?
Old Oct 27, 2002 | 05:24 AM
Chui's Avatar
From: Somewhere in the MidWest..., The MidWest..., USA
Modal Analysis work was performed on both [different sources, however] and the ITR's trimmed body is, in fact stiffer than the S2000. In terms of static bending the BMW Z3 and Porsche Boxter are stiffer, too. The ITR is stiffer than both of those as well it should be -- it's a coupe, after all.
ITR: approximately 38 Hz
S2000: ~34 Hz
Porsche: ~33 to 35 Hz
BMW: ~33 to 34 Hz
I don't recall the static bending numbers, but both of the German cars were stiffer, but both have heavier chassis so the natural frequency, omega = square root of the quantity(static stiffness/mass)].
The Audi TT Coupe was damned close to 40 Hz...
All things being equal [they seldom are, but they are close enough for comparison, anyway] coupes will be stiffer than convertibles and the smaller the vehicle the stiffer it should be.
Also, keep in mind that the data is very difficult to analyze and is subject to interpretation so one guy's 40 Hz may be another's 33 Hz. There is also discrepancy between auto manufacturer's description of the condition of the vehicle: Body in White [no glass]; Trimmed Body [With Glass -- makes it stiffer] and I forget the terminology at Ford for all interior trim minus seats, etc.
[Modified by Chui, 6:28 AM 10/27/2002]
