What RPM does your gear change?
I have a 93 accord auto. And when I'm just driving regularly, like going on highway my gear changes at 3500, when I press on gas harder it could sometimes go 4k but usually just 3500, just wondering what about you guys? When does yours gear up?
Depends on throttle angle and engine load.
Originally Posted by tasauto
Proper operation: The car starts at first gear at half throttle.
When the speed reaches about 17 - 21-mph the car shifts to second gear.
When the speed reaches about 35 - 39-mph shifts to third gear.
When the speed reaches about 54 - 60-mph the car shifts to fourth gear.
When the speed reaches 60 - 65-mph or more the lock up torque converter engages. This is felt as a slight nudge. Shift sequence ends.
The rpm may range from 2000 - 5000 before shifting depending on the throttle position. The 90-93 Accord can stay up to 68-mph in second gear.
for my 96 honda accord when driving normally it changes gears at 3000 rpms and when i push the pedal all the way down to the ground it switches gears around 6500 rpms
EK FLY
Jul 5, 2011 05:15 PM
MAD_MIKE
Feb 21, 2011 02:14 AM
