Rattling sound?
Easiest thing to do would be to have a trusted individual in the car, and place the car in D4-D1 while holding the brakes, walk around the car and try to pinpoint where the noise/rattle is coming from. Slightly increasing the engine rpm while braking will increase the load and may increase the noise. You will most likely have to get on your gut to pinpoint the sound.
FWIW, when I installed the RS-R exhaust on the '95 EX there was a mass damper, looked like a large washer/bearing, that would make contact with the exhaust under load. Initially I thought it was the heat shield that bolted to the exhaust tunnel in the center of the car. This mass damper was located at the first 90° bend where the exhaust hanger is after the resonator.
When in Park the exhaust appeared to have plenty of clearance, but once placed into D the larger diameter exhaust would more closer to the damper, and under acceleration would make contact.
Look for loose heat shields on the catalyst, under the body, broken or missing exhaust hangers, broken, missing or stretched rubber exhaust hangers.
Toyota00
Apr 3, 2013 09:34 PM
