LS B18 striped bolt hole
Old Dec 11, 2012 | 06:30 PM
Needin_VTEC's Avatar
Default LS B18 striped bolt hole
What's up guys and gals. What i got is a 91 b18 i got it for cheap and i think i found out why. I was going to drain the coolant so i took the drain plug out (the one behind the exhaust). The plug came out fine alil snug but nothing out of the ordinary. Well when i started it back into the block it started fine threaded almost all the way to the block then it got alil snug then the threads just let go. So what i'm getting at is anyone else run into this and what suggestions do ya have besides just retaping the threades and putting a bolt in it. Thanks for any info
Old Dec 11, 2012 | 09:53 PM
holmesnmanny's Avatar
Default Re: LS B18 striped bolt hole
You might be able to get by with completely cleaning out the hole and then making sure it is completely dry and then putting some rtv on the bolt threads and threading it in until you know the threads are all on, then let it completely cure for a day. It's going to depend on how bad the threads are. You were supposed to rtv those threads to begin with.
Old Dec 23, 2012 | 06:29 PM
95*civic-hatch's Avatar
just rethread it dont take the chance that it will hold
Posted from Honda-tech.com App for Android
missionaryrider
Jan 15, 2010 08:23 AM
audsyn
23
Jan 29, 2008 10:00 PM
WhoDoYouThink
Mar 29, 2006 06:32 PM
Copy Cat
Oct 25, 2005 02:13 PM
93preludes
Dec 4, 2003 01:58 PM
