bolt on the front of the block
Old Mar 28, 2006 | 08:38 PM
WhoDoYouThink's Avatar
Default bolt on the front of the block
what size is it? it is the one behind the header. mine is loose and leaking coolant. I just noticed that too. I guess that 's what i get for letting some ******* rebuild my motor.
HEADS UP PEOPLE IN TACOMA!!! DO NOT EVER TAKE YOUR CARS TO IMPORT SPECIALTY AUTOMOTIVE. DONNY IS A ******* SCUM BAG LIAR!!
Old Mar 28, 2006 | 08:59 PM
ImportMotorSpec's Avatar
Default Re: bolt on the front of the block (WhoDoYouThink)
Is it a hex key? If it is i believe it is a 14mm
Old Mar 29, 2006 | 08:13 AM
Default Re: bolt on the front of the block (ImportMotorSpec)
nope not hex.... It was a big bolt and it is bigger than a 18mm socket. I need to know what size it is so i can tighten it but i need to buy the right socket for it.
btw... I believe the bolt is for the freeze plug.
Old Mar 29, 2006 | 08:39 AM
StolenTeg's Avatar
You mean the bolt to drain the coolant from the block?
Old Mar 29, 2006 | 09:46 AM
petergriffen's Avatar
Default Re: bolt on the front of the block (StolenTeg)
drain the coolant take the bolt out since it already loose. take it into the store with you and see which socket it fits.
Old Mar 29, 2006 | 09:58 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
It's either a 19mm (same as lug nuts) or something in the neighborhood of 22mm. I can't remember exactly off-hand.
Old Mar 29, 2006 | 10:10 AM
purplegsr's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">It's either a 19mm (same as lug nuts) or something in the neighborhood of 22mm. I can't remember exactly off-hand.</TD></TR></TABLE>
I can't remember either, but the part # is 90001-PM3-003 and the actual threaded part is supposed to be 28mm, so I am betting that it's a 20-22mm. It seems bigger than the crank pulley bolt to me, at least in my mind.
As far as the leaking, it is prone to do that, but you may not need to replace it, just take it out, watch coolant poor everywhere, and put some hondabond or other grey silicone sealant on the threads (assuming they aren't noticeably stripped). Hopefully that will stop your problem.
Old Mar 29, 2006 | 10:51 AM
Community Builder
Isn't there also a large crush washer on that bolt? Might need to replace that if there is.
Old Mar 29, 2006 | 10:55 AM
purplegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">Isn't there also a large crush washer on that bolt? Might need to replace that if there is.</TD></TR></TABLE>
Yes, there is. It's not something any dealers/auto parts stores in my area stock regularly either, I guess they figure most people just don't care or flip it over and crush the other side. But I had to order it, took a couple extra days.
Old Mar 29, 2006 | 03:47 PM
sik96teg's Avatar
Default Re: (purplegsr)
its a 19mm
Old Mar 29, 2006 | 05:34 PM
Racermech's Avatar
Default Re: (sik96teg)
I cant help on the size, but the TQ is 78NM (58 lbf.ft) and "apply liquid gasket to bolt thread when installing. WASHER replace"
That is from my service book.
Old Mar 29, 2006 | 05:53 PM
vesperfx's Avatar
19 mm http://jdmlyfestyle.com/DSC041271.JPG
Old Mar 29, 2006 | 05:55 PM
sik96teg's Avatar
Default Re: (vesperfx)
i used teflon tape on mine hasent linked yet
Old Mar 29, 2006 | 06:32 PM
thank you much guys.
Much appreciated.
kaivorth
Honda Civic (2001 - 2005)
Oct 31, 2016 04:48 AM
Copy Cat
Oct 25, 2005 02:13 PM
Carnage R1
Apr 26, 2005 11:12 AM
99ls
Nov 11, 2002 09:57 AM
