Will OBD2A wiring harness work in an OBD2B car?
Old Dec 11, 2012 | 06:12 PM
brandonEM1's Avatar
Default Will OBD2A wiring harness work in an OBD2B car?
Hi Honda-Tech, hopefully someone here can help me.
I have a 1999 civic with a JDM Type-R. The car is running on an OBD1 ecu with no jumper harness. My engine harness and dash harness is all hacked up so I am going to replace it with the proper wiring. I bought the correct dash harness (obd2b) but the engine harness I got is OBD2A. So my question is, will the obd2a engine harness work with the obd2b dash harness? If not, what do I have to modify to make it work?? I hope that I can make it work because I also bought a jdm type-r ecu which is obd2a, that way I wouldnt have to get a jumper harness.
Old Dec 11, 2012 | 07:55 PM
mtber's Avatar
Default Re: Will OBD2A wiring harness work in an OBD2B car?
A civic obd2a engine harness will not work with an obd2b dash/interior harness.
Old Dec 11, 2012 | 08:25 PM
brandonEM1's Avatar
Anyway to mod it? I can't find a obd2b engine harness
Old Nov 17, 2013 | 04:48 PM
STi Guy's Avatar
did you ever figure it out? Im in the same situation right now.
Old Nov 20, 2013 | 12:34 PM
VegasInvasion's Avatar
I'm Huge In Japan
it's a major, MAJOR pain in the *** to mod an obd2a engine harness to match an obd2b chassis harness. it shouldn't be that hard to find an obd2b engine harness, the only thing I don't think will match up is the dizzy plugs which you can just re-pin, splice, or get a jumper for.
Old Nov 20, 2013 | 05:51 PM
nub's Avatar
nub
There's a lot more different than the dizzy plug. The ecu plug configuration, pin outs and chassiss harness plug wiring are all different.
Old Nov 24, 2013 | 04:21 PM
Moi Moi's Avatar
it work only you dont have any fuccion on the interior.... but what are you relly loking for you are doing a swap or what??? you have to know what you need this and what you really need this
UniqueX707
Nov 24, 2014 11:33 AM
zdiddy22
Oct 14, 2013 08:51 AM
civic-steve-94
10
May 24, 2011 09:20 PM
boostedb20z
Oct 28, 2009 11:22 AM
