Machining wheels?? How much is safe?
Old Dec 11, 2012 | 10:49 AM
Caddiman's Avatar
Default Machining wheels?? How much is safe?
So i want to shave off a few mm off of a set of wheels that i have. How much, IF ANY would be ok to do so?? Negative comments please stay away. Im looking for answers not "I think i know".
wheel are a 0 offset. looking to get them between +5 to +10
Thanks fellas
Old Dec 12, 2012 | 08:03 AM
94CivicSi's Avatar
Default Re: Machining wheels?? How much is safe?
How are you doing it? Lathe or CNC machine? My concern would be changing the position of the mounting surface relative to the rim.
Changing the offset of a wheel isn't an issue as you long as you've got clearance for calipers, suspension components and turning radius.
Old Dec 12, 2012 | 01:00 PM
fcm's Avatar
fcm
Old Fart
Kind of depends on how much material you have to work with.
I have a set of 15" TSW stealths, originally for a VW, so there is an "addapter centering ring", about 1/4" thick, to properly fit them on to my 94RS, I did not like the way they "stuck out" past my wheel arch, so I had a machine shop, machine off a 1/4" and add the Integra "seat" into the wheel, I was worried there would be a problem, but the machine shop said it would be fine as the wheel was thick enough, 7 years an no problems. 94
Old Dec 13, 2012 | 09:37 AM
Caddiman's Avatar
Im not sure what the shop is using. this is kinda new to me. I just saw that another HT member did this to his wheels. I have plenty of clearance as far as calipers go. the hub of the rim is over an inch and a half big. so plenty of room to remove. I would like to remove 10mm if possible. Im thinking 5mm is safe for sure
Rim_Repairs
Welding / Fabrication
Jul 7, 2008 08:32 PM
SlowB16
May 27, 2008 02:44 PM
siblues
May 5, 2008 09:39 AM
importdude2000
Jan 9, 2007 01:47 PM
Suprdave
May 4, 2003 11:35 AM
