Where to buy longer top hat studs?
Old Dec 11, 2012 | 07:17 AM
EKhatch's Avatar
Default Where to buy longer top hat studs?
I am going to be running some spacers on top of the struts on my Forester and am going to need longer studs for the top hats but am having trouble finding any. I would really like to get the same style press fit studs although I know I can just replace them with bolts if all else fails. Anyone know where I can get some? I checked McMaster Carr but I didn't see any metric studs. I believe they are M8x1,25.
Thanks
Old Dec 11, 2012 | 11:51 AM
EKhatch's Avatar
Default Re: Where to buy longer top hat studs?
I found that they are called self-clinching studs which helped a little but still no luck finding the size I need. I guess bolts will do. lol
Edit: I think what I am looking for is actually called a serrated stud but still no luck with M8 or M10 studs. However I am learning a lot by spending all day on Google rather than doing anything productive.
Old Dec 11, 2012 | 03:53 PM
Race Egr's Avatar
http://lmgtfy.com/?q=m10+serrated+stud
Old Dec 11, 2012 | 06:49 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
mcmaster carr has gobs of metric studs, with different options for thread length on each side.
Old Dec 12, 2012 | 02:49 PM
EKhatch's Avatar
Originally Posted by Race Egr
Sorry, should have mentioned they need to be 40-50mm long.
Not looking for studs threaded on both sides.
Old Dec 12, 2012 | 06:16 PM
Riceburner247's Avatar
I used to work for a local rally shop. We had quite a few customers coming in wanting to lift their Subarus and we ran into the same problem you're having. After searching with no luck, we had to turn to a local machinist to have them custom made.
Old Dec 12, 2012 | 06:32 PM
have you checked with the ARP?
Old Dec 12, 2012 | 08:15 PM
EKhatch's Avatar
Thanks for the info.
Didn't see anything close in their catalogue other than wheel studs which are a bit different and not long enough.
Guess there is a good reason everyone I have seen running spacers are using standard bolts.
Old Dec 12, 2012 | 08:21 PM
wantboost's Avatar
Who is Mr Robot?
ARP will custom make them
Old Dec 13, 2012 | 05:50 PM
EKhatch's Avatar
^I'm sure they do it on the cheap too. lol
I found some Polaris UTV extended wheel studs that looked promising but turned out to be 3/8" instead of metric.
Old Dec 13, 2012 | 06:00 PM
turtleman321's Avatar
any reason not to run a SAE threaded stuf and matching nut if the serrations fit snugly into the top hat?
Old Dec 13, 2012 | 06:10 PM
wantboost's Avatar
Who is Mr Robot?
Yea metric vs. Sae doesnt matter if it works
Call ARP, I know what dealer pricing is on most custom stuff but not serrated studs
Old Dec 13, 2012 | 07:26 PM
EKhatch's Avatar
Not at all. I'm going to go buy the Polaris dealer and see if they have any I can look at. All the ones I have found online I have to buy in a set of 16. Would be a waste if they didn't work.
Will do. I might know someone around here that does fab work that might be able to get me some pricing as well.
Old Dec 14, 2012 | 03:47 PM
PhilStubbs's Avatar
I agree, ARP is surprisingly affordable. I'd give them a shot
Old Dec 14, 2012 | 10:53 PM
AcuraIntegraLS-T's Avatar
If you end up finding some please let us know where, I too have a need for some longer top hat studs.
Old Dec 15, 2012 | 03:38 PM
EKhatch's Avatar
Will do. Just checked to make sure of the size and fronts are M8 and rears are M10.
Old Dec 19, 2012 | 02:11 PM
EKhatch's Avatar
Sent ARP an email a couple days ago with photos and sizes needed and no reply yet.
Old Dec 19, 2012 | 07:50 PM
wantboost's Avatar
Who is Mr Robot?
They are really busy, it took them a few days to reply to me.
Normally they need complete measurements and stuff
Such as diameter, thread pitch, stud length, thread length, stud head diameter, height, the depth of the part that fits the top hat etc
Old Dec 20, 2012 | 04:17 AM
PhilStubbs's Avatar
Last time I dealt with them I just called. I needed a z6 headstud, nut, and washer. It wasn't custom, but they handled it super quick and easy
DELshaneSOL
Feb 7, 2012 12:36 AM
kornerk12
13
Aug 7, 2009 02:46 PM
tduzzle
Suspension & Brakes
May 26, 2008 10:44 PM
