starter won't turn
Old Dec 10, 2012 | 05:32 PM
samquebe's Avatar
Default starter won't turn
1994 Honda accord LX 5 speed 2.2 MFI
It's had a hard time starting on cold days lately. The engine would just crank and crank but would never fire. looked it up and found that it could be the fuel pump relay. So in a desperate attempt to get home from work, I pulled the relay and tried to warm it up. I also found that its because of a bad solder on the relay. So I pulled apart the relay to see the solder points. After warming the relay, I put it back in to see if it would start.
like an idiot, I didnt put the cover back on the relay. a solder point came across a grounded component, made an spark, and now when I try to start it, the engine doesn't want to crank at all now
so now I'm in an even deeper rut. I turn the key to the start position and just get a single click and no turn of the engine.
any ideas?
Thanks everyone. I'm new here, and created my profile solely for this reason.
Old Dec 10, 2012 | 06:40 PM
arkangel2487's Avatar
Default Re: starter won't turn
http://109.87.33.216/manuals/auto/Honda/71.pdf.
Sorry it's the whole shibang but I was sending it from my iPhone. The starting schematic should be on pg 45. Check the blk/white wire @ the starter for power and if its there then you more than likley have a bad starter. If not then you need to work your way back but I'd start with the fuses
Old Dec 10, 2012 | 08:04 PM
jdowen2's Avatar
You may have fried the relay.
xxOldschoolxx
12
Mar 23, 2013 05:38 PM
Taimaishuuyo
Apr 28, 2012 07:57 PM
stevew84
25
Jul 17, 2008 06:16 AM
blaxican05
Feb 23, 2008 08:47 PM
Tad
Jan 3, 2006 06:37 PM
