H22 Help on Prelude
Old Dec 10, 2012 | 04:43 PM
2010coupe's Avatar
Default H22 Help on Prelude
Hello all,
ok so I need some help to comfirm my suspicions. My sons friend brought over his 98 Honda Prelude because he was getting a Check Engine light. I plugged up my OBD reader and it gave EGR malfunction and Cylinder 2 misfire with a random misfire.
I started checking it and found right away that he had a double gasket on the EGR valve (rookie mistake I guess, we've all done i'm sure). Fixed that and replaced with a new gasket-then found a cracked coil pack-replaced that right away thinking that would fix the problem. Cleared the codes and test drove it. EGR did not come back however the misfires did.
Here is what the car is doing:
-Starts and turns off immediatly
-Idles slightly high and low (feels like a small vacuum leak but not sure yet)
-Lacks power
-White Exhaust smoke (like running lean)
So i pulled plugs to check the condition-found the boots had liquid droplets (assuming coolant), inside #2 cylinder had some oil on the spark plug (ignition side).
Ok so I am assuming a bad head gasket...need confirmation though or a really bad vacuum leak (dont think so)-is there anything I might be missing???
Old Dec 10, 2012 | 06:02 PM
BigDirty's Avatar
white smoke from exhaust and fluid in or around the plugs is screaming a head gasket.
Posted from Honda-tech.com App for Android
Old Dec 11, 2012 | 03:10 PM
2010coupe's Avatar
Default Re: H22 Help on Prelude
Thanks man, thats what I was thinking......I appreciate the response
Old Dec 11, 2012 | 09:47 PM
holmesnmanny's Avatar
Best thing to do is compression test it.
Old Dec 12, 2012 | 10:26 AM
98vtec's Avatar
moderator emeritus
Compression test won't tell you much unless the headgasket badly blown.
You need to perform a leak down test or go to the parts store and buy a block test kit. On the latter test, you have a tube with blue fluid in it which attached to the radiator full. Bring the car to operating temps. If the headmaster is blown, typically you will get a result of the blue fluid turning green or yellow. It turns this color because it detects exhaust gases in the coolant system. If the block test shows nothing, do a leakdown.
Old Dec 12, 2012 | 11:55 AM
gumby7_'s Avatar
ya, a compression test wont tell ya much. I did one recently and my car passed. The overheating I was getting was the gasket. found out thru the white smoke and liquid on sparks.
Old Dec 13, 2012 | 01:43 AM
When you compression test, you are specifically testing the cylinders for problems. If he's getting a misfire for a cylinder, that is narrowing the problem to the cylinders. There is no way he is going to pass a compression test if there is a head gasket leak at the cylinder. A leakdown test is just going to narrow it to either the gasket, the exhaust valve, or the intake valve, but it's a little bit more work.
a2dadamm
Apr 23, 2012 08:33 AM
tensaiwung
Nov 4, 2010 08:42 AM
01blklude
Jul 23, 2009 08:38 PM
runnah
Jun 28, 2006 10:53 AM
TURBO4drTypeR
Jul 20, 2004 03:08 PM
