No Start/Backfires
Old Dec 10, 2012 | 09:18 AM
KillinEm18's Avatar
Default No Start/Backfires
Ok so yesterday I did some work on my H22, cooling fan stopped operating so I wired it through a toggle switch, it is wired alone, not through anything else. After I finished wiring it the car started fine, I let it idle for about 10 minutes to let it get to operating temp and to test the fan. I cut the car off and went inside for about an hour then went back out to take it for a ride. When I tried to crank it would turnover just fine the every 3-4 attempts there would be loud pop, the last one was as loud as a gun being fired next to your ear. Everything I have looked at people are saying either the distributor or it jumped timing, but could it have jumped timing when I cut it off, or attempted to start? Car ran perfectly fine before hand. Thanks in advance for any advice. This is my DD so I kind of need to get it fixed and I'm not trying to just throw parts at it.
Old Dec 10, 2012 | 09:33 AM
skylerreniger's Avatar
Default Re: No Start/Backfires
did you mess with the firing order at all? I wouldn't think the backfiring would have anything to do with what you did with wiring the cooling fan. and I would have to also agree with you with possibly the timing or something to do with the distributor.
Old Dec 10, 2012 | 09:38 AM
KillinEm18's Avatar
Never touched anything doing with timing, it ran perfectly fine after doing the fan, cut it off, went back to start it and that crap happened. lol. so confused.
Old Dec 10, 2012 | 10:00 AM
hybridmiklo's Avatar
yes, the timing belt could have jumped if it has over 90k and hasnt been replaced, or it was replaced and left loose. Sometimes in this business something happens coincedantly the same time as another. Check mechanical timing.
Old Dec 10, 2012 | 10:10 AM
Yeah idk that's fricken weird haha.
Old Dec 10, 2012 | 10:27 AM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^
A backfire is a pretty good indication that there is a timing problem, either valve or ign., also agree if the timing belt is old it may well have skipped a tooth and that can happen at any time, even when turning off the ign. 94.
Old Dec 10, 2012 | 11:06 AM
KillinEm18's Avatar
well i just went outside and it started right up.
Old Dec 10, 2012 | 11:31 AM
Haha what the hell
Old Dec 10, 2012 | 11:38 AM
fcm's Avatar
fcm
Old Fart
Maybe just a connection problem someplace. 94
Old Dec 10, 2012 | 02:38 PM
KillinEm18's Avatar
I think my distributor is starting to go because now it is cutting back some when driving. Guess ill be looking into buying some new parts. lol
Old Dec 11, 2012 | 02:41 PM
MikeM's Avatar
Check the rotor to see if its loose, and look at the inside of the distributor cap.
Old Dec 13, 2012 | 08:45 PM
TrickshoT_CD5's Avatar
its either ure ignition coil not giving enough spark. or ure distributor giving spark at the wrong time. on h and f motors the tdc sensor is inside the dizzy id swap em and see if it starts
Old Jan 7, 2013 | 10:23 AM
integradude007's Avatar
check the ecu
robA90CRXsi
Aug 10, 2009 03:43 PM
dropculture
Feb 5, 2008 02:10 PM
old_school_dohcvtec
Oct 4, 2007 03:38 PM
96integrals1505
Aug 27, 2006 03:38 PM
HUBB
Apr 18, 2004 04:57 PM
