valve cover studs
Old Dec 10, 2012 | 04:34 AM
SPR876-B18C1's Avatar
Default valve cover studs
hey guys just looking for some conformation here ..
so i was changing gasket and spark plug seals when i happen to break two of the nuts used to close back up the valve cover ..
just wanted verification if this [art number is the correct thing i should get .. as when i google it i keep getting cr-v engines .. im told b18c and crv uses the same bolts/studs
heres the part number 90012-PM7-000
thanks in advance
Old Dec 10, 2012 | 10:07 AM
fcm's Avatar
fcm
Old Fart
Default Re: valve cover studs
if you mean the blot, #18... http://www.acuraautomotiveparts.org/...s=&view=normal then yes. 94
Old Dec 10, 2012 | 11:51 AM
yes 18 but i also broke one the ones that cover the spark plugs .. looks like number 21 .. but 21 is the actual nut cap .. i need the screw its attached to as well .. wonder if that same part (18) is the correct bolt
if anything im gonna take a pic soon and upload it
next problem tho is that one of the #18 bolts the nut cap jus keep spinning and spinning .. wont come off.. so its looking like im gonna have to cut it off .. but i guess ill be buying 4 of those bolts tho
Old Dec 10, 2012 | 12:45 PM
fcm's Avatar
fcm
Old Fart
It shows you need oly 4 of them, so the ones for the cover are differant, but I can not find them anywhere, are you sure they are not part of the VC, I can't look, I have an RS, [B18b]. 94
Sic_DA_Nine
Feb 1, 2008 09:30 AM
ITR32
Jul 27, 2007 06:09 AM
plikit
Jun 4, 2007 06:56 PM
colombian linx
Nov 29, 2004 08:20 PM
ActiveAero
Jun 7, 2003 02:31 PM
