Sunroof rear drains
Old Dec 8, 2012 | 12:05 PM
Elevorett's Avatar
Default Sunroof rear drains
Hey guys, 1990 EF Si hatch checking in.
The rear lines that drain the sunroof in my car are plugged and sometimes when the car is parked uphill it will collect water. When the car levels out or I brake, the water finds it's way onto my head.
How do I fix these lines? Can I blow compressed air through them, and if so, how do I access these lines?
Thanks in advance,
Old Dec 8, 2012 | 12:24 PM
Tyson's Avatar
Default Re: Sunroof rear drains
Should be the same with civics.
https://honda-tech.com/forums/showth...=sunroof+drain
Old Dec 8, 2012 | 12:30 PM
Elevorett's Avatar
Noted, thanks. Will give it a go.
Old Dec 8, 2012 | 01:41 PM
bgdriver's Avatar
I just took mine off at the sunroof and ran compressed air through it, took like 2 minutes. You will get nasty smelling water all over you and your interior, so be prepared for that.
Old Dec 10, 2012 | 03:21 PM
Tyson's Avatar
if youre getting dirty water in your interior, youre doing it wrong.
just saying.
citrus3000psi
May 19, 2008 02:52 PM
blackeg
Mar 9, 2008 05:51 PM
rawdil49
Jun 25, 2003 01:40 PM
Ronin Integra8
May 25, 2003 08:38 AM
