seatbelt light issue/battery drain
Old Dec 8, 2012 | 10:15 AM
91grape's Avatar
Default seatbelt light issue/battery drain
when i got the car the buckle is missing the cover, and the connector is missing, and they also cut the connector off the harness too. could i just wire the two from the harness together, or wire in a inline fuse to it to make it think its buckled?
also i have a new battery in it, but i have a draw somewhere. is there a common cause that makes the battery drain over the course of a few days? alternator charges at 13.5v, and batt is brand new like i said. its a real annoying inconvenience. all help is appreciated. thanks.
Old Dec 8, 2012 | 02:57 PM
GPC91's Avatar
Default Re: seatbelt light issue/battery drain
i had a drain in my car. all i did was just disconnected the battery every time i parked it for anything longer than like a half hour. i know its the lazy way of doing it. but wiring is confusing and this works till you can figure it out.
Old Dec 8, 2012 | 09:42 PM
ThePizzaMan's Avatar
Strange... my CRX has the same problem. Seatbelt lamp flashing and new battery drains. Coincidence?
Old Dec 8, 2012 | 09:49 PM
https://honda-tech.com/forums/showpo...90&postcount=8
and...
https://honda-tech.com/forums/showth...ighlight=drain
I was going to take it into honda anyway for the seatbelts... hopefully they'll just fix it for free under lifetime seatbelt warranty.
Old Dec 8, 2012 | 09:52 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
both of my seatbelt switches are disconnected under the seat.
Old Dec 8, 2012 | 10:25 PM
... and that disconnects power to the seatbelt circuits?
Old Dec 9, 2012 | 07:42 AM
91grape's Avatar
Seatbelt light only flashes when the car is on and running, not when it's off. Also noticed the door open light stays on. I don't see how it could drain the battery unless I have a wire grounded at a courtesy lamp, because the done lamp is switched off.
Old Dec 10, 2012 | 02:52 PM
Apparently the problem is the seat belt unit shorting out and drawing power? I have an appointment at Honda tomorrow to check out the seatbelts under the lifetime warranty. I'll post results.
Maybe not a coincidence... I have nothing else staying on, alternator good, battery cable replaced... We'll see what happens.
Old Dec 11, 2012 | 03:17 PM
New retractors on order for free... we'll see if that was the culprit.
Old Dec 13, 2012 | 05:34 PM
91grape's Avatar
did you pay a diag fee?
UPDATE
ok, after some poking and prodding around, i havent found anything that could possibly cause it....guy at work said it could be the alternator draining and killing it after it shuts off. who knows. i took the test light and disconnected my neg bat cable and put the test light in series and touched it to the neg post, and it lit up. so apparently i have something somewhere thats grounded. dunno where tho. so i attached the test light to the neg post again and checked the bjb(under hood fuse panel), and all my 20-30amp fuses lit up and so did the bolts holding wires etc. i dont know if thats normal on a honda. i work on diesels, and thats all im use to. all im asking for is a nudge in the right direction. thanks.
Old Dec 14, 2012 | 06:27 PM
Nope. No fee. Seatbelts warrantied free of charge. =]
Old Dec 16, 2012 | 12:25 PM
91grape's Avatar
man thats nice. i got to get up there and drop my car off sometime.
cserrano34
Classic Hondas
Jan 20, 2015 04:16 AM
mikenomy
Honda Ruckus and Scooters
Mar 22, 2010 04:27 AM
I Like Hondas
20
Oct 18, 2006 01:54 PM
elmalouno
Nov 10, 2004 12:52 PM
sky88
Jul 17, 2004 11:30 AM
