d15b1 in 89 hatch problems
Old Dec 6, 2012 | 09:17 PM
LuckyJDM's Avatar
Default d15b1 in 89 hatch problems
First I had forgot to connect something to the starter making the battery get very hot and giving no power to the car. that is now fixed.
Second, the car was cranking and flames were coming out of the exhaust manifold there is no headers on right now so we could literally see the flames. that is still a problem.
Third, the check engine light stays on when key is turned. First ecu was giving code 6 and 10 with flashing red light. I fixed those problems now the ecu doesnt flash red or give any codes. Check engine light still stays on after changing main relay. Also changed distributor. Car still does the same thing blowing fire out of the exhaust manifold and not starting it cranks though.
Any ideas one why the check engine light would stay on after the key is turned. Also what is causing the flames im guessing ignition timing I played with it but nothing still causing the flames to shoot out each cylinder.
Another thing I forgot to mention, spark plug 1 and 2 wires have spark but 3 and 4 dont. This is with the new dizzy.
Old Dec 7, 2012 | 08:47 AM
91legend's Avatar
Default Re: d15b1 in 89 hatch problems
ok so you changed the distributor, did you change the cap and/or rotor?
LITTLE flames come out the head on the exhaust side whenever there is no exhaust manifold on. Think about what happens inside an engine. COMBUSTION.
Where did you get the distributor from? if from autozone, return it and get your money back and go somewhere else. TRUST ME ON THIS.
Old Dec 7, 2012 | 10:23 AM
kenji801's Avatar
The whole distributor was changed with new spark plug wires
Old Dec 7, 2012 | 10:47 AM
91legend's Avatar
ok so my question still remains, did you get it from autozone?
Old Dec 7, 2012 | 11:30 AM
kenji801's Avatar
Nope and I also got one from a friend with the same motor and he pulled it out to check if it works still same problem
Old Dec 7, 2012 | 12:22 PM
91legend's Avatar
if you have a multimeter, check your wiring at the distributor. cant remember which pin it is but make sure it has 12v. also, how do your spark plugs look?
AudioFunk
Jul 29, 2013 11:02 AM
leochilo
May 26, 2010 08:15 AM
SofaKing
Aug 23, 2005 05:55 PM
EVIL TYPE R
Feb 21, 2005 02:31 PM
zCivic
May 23, 2002 04:56 AM
