Would it be pointless to paint my intake with hi-temp spray paint?
Old Oct 19, 2002 | 07:04 AM
RegRedTeg's Avatar
Default Would it be pointless to paint my intake with hi-temp spray paint?
My intake has some scratches on it and just wondering would it be pointless to use hi-temp spray paint.
Old Oct 19, 2002 | 09:27 AM
Civmochris's Avatar
Default Re: Would it be pointless to paint my intake with hi-temp spray paint? (RegRedTeg)
i dont think you would need hi temp spray paint regular should do just fine the intake doesnt get that hot.
jusst my thouht
Civmochris
Old Oct 19, 2002 | 09:30 AM
integra-modder's Avatar
Default Re: Would it be pointless to paint my intake with hi-temp spray paint? (Civmochris)
pointless?
well, thats a question that only you could answer. If you think the time you spend doing it is worth the result then sure, and if not, well you get the point.
I think It might be a good thing because it would act like an insulater, keeping the high temp air from heating the intake pipe. However it could also prolong the intake pipe cool down.
Old Oct 19, 2002 | 09:52 AM
Jsracingintegra
Guest
Posts: n/a
Default Re: Would it be pointless to paint my intake with hi-temp spray paint? (integra-modder)
I think kigh temp paint needs to be really hot after it's painted to cure the paint.
You dont need to do it.
Old Oct 19, 2002 | 11:30 AM
Weston's Avatar
Default Re: Would it be pointless to paint my intake with hi-temp spray paint? (Jsracingintegra)
Yeah, I looked into doing this but all the paint I looked at required to be heated to like 300F or so to cure. I would think it would help keep heat from getting to the intake pipe, but if it does get hot, it should actually cool down as fast or faster than before. That is because a ton of air is rushing through it and the ceramic paint should help more heat from coming in. It won't cool down by just sitting in a hot engine bay.
Old Oct 19, 2002 | 11:44 AM
RegRedTeg's Avatar
Default Re: Would it be pointless to paint my intake with hi-temp spray paint? (Weston)
yeah that was the problem but on the back of the hi temp paint can it sais youc an cure it in a oven so my intake will fit in the oven but im kinda weary of doing it, lol
Old Oct 19, 2002 | 12:27 PM
blkbeast's Avatar
New User
i don't think it would be worth the time. the air would be travelling too fast through the intake pipe to be heated up by the pipe itself. my 2 cents
Old Oct 19, 2002 | 09:39 PM
RegRedTeg's Avatar
I ended up doing it, I dont know if it helped at all..doubt it but it looks alot better..I used a silver hi temp paint so it has like a exhuast, or header look.
Old Oct 19, 2002 | 09:47 PM
n0 iNTegRiTY's Avatar
its really up to you man.
thatasiankidtony
Jul 22, 2008 08:49 PM
JamesV
Nov 25, 2005 06:24 AM
DJ_SaNdOz
Jul 15, 2005 06:29 PM
HONDA-2NR
Feb 19, 2004 08:51 PM
ILOVEGIRLS
Dec 21, 2001 09:19 AM
