95Acura integra problem
Check all your ground wires under the dash and in the engine bay, also check your fuel pump to see if its working ( it will make a buzzing noise when you turn the key to the on position)
Basic test, turn ign. switch to the run position, [NOT all the way to start] listen for the fuel pump priming.
When you turn on the ign. the cluster will "light up" including the CEL, at the same time the fuel pump will start running, [priming] after no more then a few sec. the CEL will go out and the fuel pump will stop priming, is that happening? 94
Ruggeh
31
Jan 10, 2016 12:00 PM
Championship
Nov 25, 2010 05:36 PM
