1996 accord 2.2 non vtech big problem..i think
I wish somebody could really help me out on this. My accord is only running on 2 cylinders right now. Only the 2 in the middle I think woiuld be 3 and 4? I just bought new plugs and wires and installed them but no luck there. I swapped ignition wires from the good cylinders to the bad even on the disributor full swap....no luck. I can smell the unburned gas and a little blue smoke is coming from the valve cover because I checked around the head for leaks while it was smoking and didn't find any leaks at all. Can somebody please give some insight on this any would be appriciated greatly.
I just want to add everything I've done to it utill this point. Timing belt job witnessed spot on, band new iacv valve, took the fitv off cleaned and tightned it. Oil and filter change, new valve cover gasket and seals, new spark plugs, new plug wires installed this morning, new map sensor new tps sensor and new upstream 02 sensor my car doesn't have a cat I had that and the sensor deleted alli have is straight pip with exhaust., oh and I also checked the distributor cap for any oill leaks.... none don't eally know what else it could be as I'm hoping all is well with the block (fingers crossed)
Mason Edmison
Oct 13, 2017 07:52 AM
asdunbar90
Oct 14, 2015 03:48 AM
not-a-stang
Apr 8, 2008 08:45 AM
