Source for OEM ITR brake pads
I'm upgrading to the ITR brakes on my turbo LS. From what I've read the OEM pads would probably best fit my needs (spirited street driving, hopefully a first time track day).
Looking to see where you guys have found the best price online for oem pads. Looking for a deal on SS brake lines too. Thanks
brakes is one thing i wouldnt recomaned buying oem, true they are good quality, just expensive
brakes are a wear item, go to advanced auto, o reily, auto zone, etc, there rotors are good and are super inexpensive, and i think advanced has a replacement warranty on them,, and get there higher end pads, non metaillic , be just as good as oem and alot less expensive
A simple google search can quickly net you about 4-5 OEM parts places. And you'll notice that all are within a few bucks of one another.
SS brake lines are pointless for a street car or casual HPDE car.
Cool Cool Island Breezes. BOY-EE
What kind of question is this? "Where can I get OEM pads for an ITR?" Try leaving your house. Pick a place. Chances are they'll have some. Or...if you're scared of the outdoors, use a simple search site. You'll find answers AND pr0nz. You ask a ridiculous question and people ACTUALLY answer...and you call them ****. You have mastered the internet.
I wouldn't use OEM pads for any kind of track use. A lot of people have luck with Stoptech Street Performance. I like them better than hawk HP+ and they're idiotically cheap. My GF's stock AP2 (S2000) has em. They make really good street pads and they never faded at the track with me beating on them for a whole session. I usually hate "performance street" category pads. I love those Stoptechs, though.
www.rockauto.com. Centric rotors. Stoptech SP pads or Akebono Ceramic performance pads if you can give up stopping power to achieve less dust. would you like me to chew your food for you?
Actually several of the posts I've found implied that the actual honda compound was better than the various parts store pads. All though some did mention the Akebono pads from Napa as being decent quality. Posts like this:
i have used numerous pads and for what the op wants, nothing better than oem. i have tracked them for a full day at streets of willow in what seemed like 900 degree heat and experienced minimal fade. plus there is nothing as reliable as an oem pad and its the best value by far.
For low dust, no squealing, and good bite, I recommend the stock pads. Their performance is better than the HPS, and they're cheaper, too. (The HPS is around $77 for a set of front pads, and stock front pads, part number 45022-ST7-R02, is $41.38 at Delray.)
If you take out the low dust criterion, then I recommend the Hawk HP+ (HP Plus) rather than the stock pads. They both perform well, but the HP+ will last a bit longer on the track and have a bit better bite. But they dust quite a bit, and they're more expensive ($95).
Open to additional input on pads for a DD that sees regular brake abuse ... 120+ down to 60... hopefully a track day if I can ever get that lined up.
http://www.hawkpadsdirect.com/?gclid...FYl7QgodV2cARg
SS brake lines for sure, brake feedback is much better, even as a DD. 94
Just replace with new OEM lines unless this is a weekend tracktoy only.
SS lines on a daily is moronic. Feedback is slightly better, but it isn't worth driving with them and exposing them to the elements which might possibly cause them to fail (read the warnings about this). There is a reason why OEM's use heavy rubber for that distance between the line and the caliper.
And although we have changed/replaced more then a few OEM brake lines over the years at our shop, we have never had to replace SS lines.94
I have had SS brake lines on my 94RS since new, [first thing I switched] car is a DD and to-crossed and drag raced all it life, the SS lines still look nearly brand new, and IMO there is more then just a "slightly better", OEMs use rubber because it is cheaper.
A hose "looking new" has nothing to do with this (you can't see the inner teflon, can you? And that's where issues would develop). And the difference between a new SS hose and new OEM hose is very minor. Basically, it is a worthless upgrade unless you see a lot of track and autox time. Money spent on SS lines is better spent on better brake pads or stickier rubber (or new OEM brake lines if the originals are old).
OEM's use rubber because it is flexible, does its job and debris won't get in between the SS covering and inner teflon hose.
Im using StopTech pads on my mini cooper rotors and am pretty happy. I also upgraded to SS lines. One of the things you wanna look for when buying SS lines is buying lines that are coated.
I've had coated StopTech lines on my car since 2004 without any issue.
I think someone was referring to genuine Acura pads being better than the parts store house brand pads. In which case...yes...Acura pads are better. Parts store pads are so terrible.
Well I took the StopTech recommendation and ordered their pads and lines from R1Concepts. I never thought I could read so much about brake pads.
I always order my OEM parts from http://www.acuraautomotiveparts.org/
Great customer service and quick shipping. Also mainly because they are located in GA and I'm only in Tennessee.
hondaracin24
Nov 19, 2004 02:48 PM
full Circling
Jul 10, 2004 01:30 PM
