H23 VTEC NITROUS QUESTIONS
Old Dec 4, 2012 | 01:38 PM
H2Bravo's Avatar
Default H23 VTEC NITROUS QUESTIONS
I am currently in the process of planning out my next build i recently spun a bearing in my bottom so now that its time ot rebuild im looking for what ever input i can get. What im trying to do is go with 13:1 forged pistons sleeved block and i would like to to run a 150 shot. The motor currently has Skunk 2 stage 2 pro series cams. Is 13:1 to high for that much nitrous?? I am still on the line about using race gas. Any input would be greatly appreciated
Old Dec 5, 2012 | 04:13 PM
H2Bravo's Avatar
Default Re: H23 VTEC NITROUS QUESTIONS
bump please need input
Old Dec 5, 2012 | 04:54 PM
snobordboy's Avatar
Moderator
I think it will come down to the fuel you use, and a great tune. If you throw too much timing at it, things will go boom!
Sleeving the block and running forged pistons will help for sure though.
Are you planning to do a dry shot and add fuel from the ecu?
Oh and since you have already experienced a spun bearing, make sure that all of the bottom end clearances are spot on, and the crank is balanced perfectly, the 95 mm stroke is not very fond of high rpms.
Old Dec 5, 2012 | 05:20 PM
H2Bravo's Avatar
i was already running at 100 wet shot and im still on the line between which fuel i would use what are your recommendations
Old Dec 5, 2012 | 05:26 PM
H2Bravo's Avatar
also would it be better to run 12:5 compression pistons??
Old Dec 6, 2012 | 08:42 AM
snobordboy's Avatar
Moderator
If you have it available, I would run E85, and 12.5 might be easier to work with on pump gas if that is your only choice. If this is a track only car, go with the higher compression and either E or race fuel.
Old Dec 6, 2012 | 03:43 PM
H2Bravo's Avatar
one of the neighboring towns where i live sell 110 octane right from the pumps do you think that will be good enough
DsAllMotor
Aug 7, 2013 09:22 PM
jamescb77
Apr 1, 2007 10:25 PM
oianarchy
Dec 11, 2006 07:09 AM
3gLudeH22A
Jan 2, 2002 06:07 PM
