Transmission lag from 1st to 2nd gear.
So I bought my brothers EM2 2002 Honda Civic EX Automatic. He was the original owner his transmission gave out at 228k. the car has been sitting for over a year. I just recently had the transmission rebuilt. at first the car shifts fine but after about 30 mins of driving when I'm at a stop, 1st gear lags to shift to second gear. It will go to abour 3500 - 4000rpm before shifting. It only does this after driving for a bit.
my question is my battery is pretty weak. never replaced the battery just jump started it a few times and it turns on. Could a bad battery cause my computer for my transmission to shift like that. ?
http://www.atra.com/articles/transmi...inal_corrosion
i took it back and he said that was normal for a honda. Also told me i should change the battery because it was weak and has been sitting for over an year I have a 12k warranty on it.
well i replaced battery. I didn't have the correct battery in the car and the hood support rod was on my positive. I'm going to replace my shift solenoid hopefully that fixes that problem.
what do you recommend i do ? i was gonna charge my air filter and my plugs are still good.
oneeezy
14
Aug 24, 2010 11:55 AM
