Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
coolant mixture question
Old Dec 3, 2012 | 06:33 PM
mattbatson's Avatar
Default coolant mixture question
so I went to the dealer and bought a gallon of antifreeze for my 09 si with 40K miles cause I'm a little **** about maintenance.
anyways, last night I'm draining and filling and when I go to fill I notice the honda antifreeze is premixed 50/50.
Hmm, I hadnt noticed that before, and now was worried that I had enough.
When I do my toyota, the dealer sells their special read coolant (yeah, toyota does the scam too...must buy coolant from them, lol) and it is not premixed, so I guess I didnt bother looking.
I ended up adding probably another half gallon of water, although not sure as I didnt measure it out....
So, my question is do I need to do this all over and THIS time go buy two gallons of antifreeze?
Is my antifreeze diluted too much?
thoughts?
Old Dec 4, 2012 | 08:38 AM
martinklie's Avatar
Default Re: coolant mixture question
More water will aid on cooling the engine but lessen the corrosion resistance and increase the freezing point closer to 32 deg F.
http://www.magers.org/handy/antifreeze.html
Noting you live in FL one would feel its fine but you are 2/3 water. I would take the opportunity to balance the mix better.
Old Dec 4, 2012 | 04:45 PM
mattbatson's Avatar
sound advice
alrighty, off to the dealer I go
thx
Old Dec 16, 2012 | 09:40 AM
F1HondaS2000's Avatar
Honda genuine coolant is always the best.
Old Dec 16, 2012 | 12:20 PM
mike703's Avatar
ive always used the cheapest 100% green coolant that autozone sells and then cut it myself with distilled water. thats all you need to do. why pay for the 50/50 mix when essentially youre paying for water at the rate of about 16 bucks a gallon. if its 16 bucks for a gallon of 50/50.
99bb6
10
Sep 23, 2004 08:36 PM
fc3sol
May 4, 2004 10:24 PM
Nizzy
Feb 10, 2003 01:05 PM
Nizzy
Feb 10, 2003 12:07 PM
Rory Breaker
Aug 23, 2001 09:04 PM
