Will OEM lug nuts bolt down properly - ARP extended studs, 15MM spacer, OEM wheels
Ordered a set of ARP extended wheel studs and 15mm hub centric spacers to flush out the rear end. I'm rolling on 95 SE wheels and would like to know if I can re-use my factory lug nuts or not. If I had all the parts in front of me, I'd check the fitment. I would like to stay away from open ended (tuner style) lug nuts if possible, just so it looks completely factory looking.
I've been trying to find a longer "OEM" style lug nut with the Honda ball seat surface without any luck. Thanks for any help.
How long are studs? Do some math. Bottom out the nut on the stud and measure from the base of the lug to the seat of the stud and if that's shorter than your rim seat thickness plus your wheel hub and rotor thickness plus your spacer thickness, you are good.
DRFlickner
68
Jan 31, 2011 12:30 AM
