'98 Integra ABS Pump Reinstall Help
Hi,
New member here. I have a 98 integra GRS. I need to reinstall the ABS pump. The brake lines going into the pump are displaced enough that I can't be sure what pipe goes where. Does anyone have a diagram of what brale pipe goes in which hole? I searched all over. Any help would be appreciated. The nearest I can figure this is the layout for the two connections into the pump and the four out. This is top down looking in from the engine bay:
0 - Don't know
...........................................0 -Master Cyl Top in
0 - Don't know
0 - Don't know
...........................................0 -Master Cyl Side in
0 - Right Front out
0 - Don't know
0 - Don't know
0 - Don't know
0 - Right Front out
This may help. it will be hard to trace the lines but doable...
http://www.acuraautomotiveparts.org/...s=&view=normal 94
