Help car won't start
Old Dec 1, 2012 | 07:26 PM
Hondaguy83's Avatar
Default Help car won't start
I'm working on a 91 Honda civic. Has spark, fuel,compression and just cranks over but doesn't start.
Old Dec 1, 2012 | 07:33 PM
Dioxine's Avatar
Default Re: Help car won't start
What were the compression numbers? Put the motor to tdc and check the dizzy to make sure the rotar is pointing to the number one cylinder and check your spark plug order.
Old Dec 1, 2012 | 10:28 PM
Hondaguy83's Avatar
Checks out fine. Still no start.
Old Dec 2, 2012 | 12:30 AM
swordofdoom's Avatar
Check your cap, rotor and spark plugs first. A bad rotor but having spark = No bueno.
Old Dec 2, 2012 | 10:37 AM
Hondaguy83's Avatar
Checked already n did a tune up. Same problem.
Old Dec 3, 2012 | 09:04 AM
fcm's Avatar
fcm
Old Fart
You need fuel, spark, compression and both valve and ign. timing for engine to run, you are missing at least on of them.
I would start by confirming valve timing is correct, [maybe timing belt skipped a tooth].
Then confirm compression, ign. timing and spark, [use HEI spark tester]. 94
Old Dec 3, 2012 | 12:49 PM
Hondaguy83's Avatar
All checked out fine
Old Dec 4, 2012 | 05:01 AM
fcm's Avatar
fcm
Old Fart
Then engine should run, something is missing, [or low]. 94
Old Dec 4, 2012 | 01:07 PM
Hondaguy83's Avatar
Ima take my chances n switch distributor anyways. Doing it now
Old Dec 4, 2012 | 05:24 PM
Hondaguy83's Avatar
Fixed. . New distributor worked!!
Old Dec 5, 2012 | 04:40 AM
fcm's Avatar
fcm
Old Fart
So no or poor spark. 94
Old Dec 5, 2012 | 05:21 PM
Hondaguy83's Avatar
Poor spark!! Was orange
gowenburnett
May 30, 2011 05:20 PM
Ek9_Cuhzz
58
Jan 7, 2011 04:54 AM
dashocker
Sep 1, 2008 03:26 PM
purplexs650d
Oct 17, 2006 12:31 PM
g2turbo
Sep 17, 2003 08:31 PM
