hepl h22 die after 30 seconds
Old Dec 1, 2012 | 11:57 AM
teamkosmos's Avatar
Default hepl h22 die after 30 seconds
So this is the problem i change the dizzy .fuel pump fuel filtrer .and keeps dying ! Any help is allways good! Thanks
Old Dec 1, 2012 | 01:48 PM
HaPpYfAcE's Avatar
Default Re: hepl h22 die after 30 seconds
are these all brand new parts that you installed? does it sound like it's idling normally when you start it?
Old Dec 1, 2012 | 11:14 PM
holmesnmanny's Avatar
If an OP doesn't bother to give out any information, why should we bother to give out any information.
Old Dec 2, 2012 | 06:17 AM
Shiloh51933's Avatar
Need symptoms, DTC's, ect...
Old Dec 2, 2012 | 11:20 PM
f20bprelude's Avatar
it could be anything from timing issues with the dist. to intake sensors, crank sensors, making sure your firing order is correct. Need more info to help.
XRSLUDE
Aug 17, 2006 03:40 PM
Rudelude22
Jan 17, 2006 05:11 AM
92acclude
Jan 31, 2005 05:33 AM
jdmh22bubble
May 11, 2003 12:40 PM
