Transmission & Drivetrain Gearboxes, Differentials, Clutches
Teggy auto shift lock issue
Old Dec 1, 2012 | 05:23 AM
jdmh22eg2's Avatar
Default Teggy auto shift lock issue
Ok few weeks ago i bought my wife a db7 auto. Runs/drives great, but today she gets in to leave and it wont come out of "park". So i go look at it. I put key in shift lock and it moves like normal. But the min i take key out while car is in park it stays in park and won come out.
Anyone had this issue or know a way to "by pass" the lock so she does mot have leave in "n" and use ebrake to park?
Old Dec 1, 2012 | 05:43 AM
MikeM's Avatar
Default Re: Teggy auto shift lock issue
Check the brake light switch. Have your wife step on the brake pedal, and see if the brake lights are working.
Old Dec 1, 2012 | 05:53 AM
jdmh22eg2's Avatar
Hahaha idk i did not think of the brake switch. When she gets back i check it out
Old Dec 1, 2012 | 05:56 AM
MikeM's Avatar
Ok, let me know what you find.
Old Dec 1, 2012 | 06:19 AM
jdmh22eg2's Avatar
Nope not the brake switch. Brake lights go on and off as they should, and no blue platic pc's in floorboard
Old Dec 1, 2012 | 06:41 AM
MikeM's Avatar
Take out the center console, and check the shift lock solenoid with a test light or dvom, it should make a clicking noise with the key on when you press the brake pedal.
Old Dec 1, 2012 | 07:59 AM
jdmh22eg2's Avatar
Ok will do at the shop tmrw. It is now doing intermitenly, so prob a bad solenoid like u said.
Old Dec 1, 2012 | 08:29 AM
MikeM's Avatar
When you checked the brake lights, was the shifter working. If its intermittent, the brake switch would be my first choice. Brake switch faillures are fairly common. The next time the problem occurs, unplug the brake switch, and use a jumper wire to check the brake switch. You can just replace the brake switch for about $50.
DeeFry
Dec 2, 2018 09:41 AM
krisfnbs
Mar 16, 2011 01:29 PM
geneva
Jun 11, 2008 01:46 PM
DC5_lov3r
14
Aug 7, 2007 01:24 PM
greaselightning
Feb 12, 2003 01:17 PM
