best ecu to use for f22b1
Old Nov 30, 2012 | 07:38 AM
bigbpatel's Avatar
Default best ecu to use for f22b1
i have a 94 accord wagon, its and lx and was non vtec .
now has a f22b1 and i wanted to know what the best ecu to get is?
i read some people say to get a P0A (OBD1) and some to get a chipped ecu...what would be the best for tuning and turboing?
i was thinkin about getttin the hondata ecu tuner depending on what ecu i get.
thanks
Old Nov 30, 2012 | 07:54 AM
TheMuffinMan's Avatar
He knows where you live!
Default Re: best ecu to use for f22b1
Good luck trying to tune a stock ECU for a turbo.....
If you are truly trying to go that route a chipped P28 is going to be the easiest route.
Also, the P0A is not compatible with Hondata.....so I'm not sure where you got your info.
http://www.hondata.com/ecus.html
Old Nov 30, 2012 | 08:40 AM
bigbpatel's Avatar
gotcha, so chipped p28 would be the best one?
i just googled it and read a few other peoples threads adn wasnt sure so thats why i posted this thread.
thanks for the response
Old Nov 30, 2012 | 08:57 AM
bigbpatel's Avatar
http://www.ebay.com/itm/170896138008...84.m1423.l2649
Old Dec 1, 2012 | 07:12 AM
GhostAccord's Avatar
I would suggest a chipped P28 and the Neptune Demon over the Hondata S300. You would need a chipped ECu that is different than the one in your link.
Neptune has great customer service and great tech support! Hondata is hit and miss!
Old Dec 2, 2012 | 05:34 AM
bigbpatel's Avatar
http://www.youtube.com/watch?v=rtaEsxAo-ug
sounds good, thanks
hows this:
http://www.hamotorsports.com/neptune-rtp-package.html
or does it need to be a chipped p28?
Old Dec 2, 2012 | 06:05 AM
In today's Honda terms that is what people consider a chipped ECU.
What they have listed there is a P28 spec ECU. What that probably means is that they took a non VTEC ECU and converted it to VTEC. All it takes is soldering in a couple components and it's pretty much as good as a P28. That is what most Honda enthusiasts today refer to as a chipped ECU.
The term "chipped ECU" is basically any stock Honda ECU that has been modified to be tuned. Whether it be via external hardware connected directly the the ECU... ie Neptune & Hondata. Or an EEPROM chip that has been programmed externally and put into a chip socket.
In the early days of tuning the car was hooked up to the tuning hardware, then run, datalogged and tuned. Then the tuning hardware would be unplugged and the tune that was created would be burned to an EPROM chip. In turn that chip would then be put into the ECU in place of the tuning hardware connector.
The hardware was usually a stationary PC or laptop that most people didn't want to have tethered to their car with a cable. So they would burn a chip to replace all of the tuning hardware.
Old Dec 2, 2012 | 07:00 AM
bigbpatel's Avatar
gotcha, thanks for clearing up my questions. greatly appreciated
feel like such a
Old Dec 2, 2012 | 11:53 AM
You're welcome! Don't worry about it. Everyone has to start somewhere!
Old Mar 6, 2018 | 12:00 PM
Young Rez's Avatar
you seem to know a lot lol do I have to reflash
the ecu if it' set up for a civic? Because my p28 chipped won't start my car I have f22b1 as well
Old Mar 6, 2018 | 12:15 PM
MAD_MIKE's Avatar
MM Gruppe B
This generation requires a chip to be burned, there is no flash programming in Hondas until '06+
As for plug and play, you will need to ...
  • Move the wire at ECU pin A6 to pin A11
  • Move the wire at ECU pin A11 to pin A6
To make a P28(Civic/Integra) ECU work in the 94/95 Accord.
Old Mar 6, 2018 | 12:24 PM
Young Rez's Avatar
same for 97 accord?
Jdm_Ego
12
Sep 27, 2010 03:42 AM
b20vdelsol619
Aug 23, 2008 11:49 AM
hondakevin21
Jul 30, 2006 11:24 AM
badasshatchhh
May 1, 2005 07:46 PM
phatcivic99
Nov 24, 2003 10:45 AM
