Transmission & Drivetrain Gearboxes, Differentials, Clutches
Gsr trans trans in 5th shifter moves through gears. Help?
Old Nov 30, 2012 | 06:50 AM
Jkvekcivic's Avatar
Icon6 Gsr trans trans in 5th shifter moves through gears. Help?
I have a 97 civic ex with a b20z2 and gsr trans.
I slowed to make a turn on the road where I live and when I shifted down, as I let out the clutch the car lockup. I quickly responded and the shifter wil move through 1-4 but 5th is solid. I have did a lot of research and can't seem to over come these symptoms resolved. I have check around the car, seen a driveshaft boot is leaking grease, well freshly spun grease on trans. Passenger side. Also just found out I had a leaking clutch slave cylinder. Have replaced, will bleed today. Would a slave cylinder have cause on this issue? All help is greatly appreciated. Thanks.
Old Nov 30, 2012 | 02:27 PM
parts@synchrotech's Avatar
Default Re: Gsr trans trans in 5th shifter moves through gears. Help?
Did you check the fluid level to make sure you did not run it low on fluid? 5th gear is on the very outermost part of the transmission and the first to burn up when run low on fluid.
Old Dec 1, 2012 | 11:06 AM
Jkvekcivic's Avatar
Well I have the trans opened.. Come to find out when I went to drain the trans hardly anything came out. Looking over the gears and all everything looks fine. First time really with a trans. Bin through tons of research. The problem I am having with the trans is the 5th/r fork will engage into reverse but it never seem to come out of 5th. As it slides back down, it won't go down in order to get it on neutral. I'm really tryn to gain knowledge, and get this problem solved. All comments are appreciated.
Jkvekcivic
Dec 17, 2012 10:30 PM
never_satisfied
Apr 22, 2009 08:01 AM
Will_H
Sep 4, 2008 08:32 PM
FGirl13
Nov 29, 2007 05:25 PM
sk8
Apr 19, 2004 10:06 PM
