Strange symptoms after changing1990 Accord ignition coil..Please any help appreciated
Hi Im new....great forum..lots of smart Honda Peeps out there..Anyway I changed a faulty ignition coil it started and ran fine.Next thing I know I have no blower or any function from the climate controls no blower etc. Also when I push in the clutch it makes the same grinding sound that a bad break pad or screwed up rotors would..just to give you an idea of the sound. But after the grind sound when the clutch is all the way to the floor it doesnt make the sound and it seems to work fine despite the sound.AND its hard to turn my key in he ignition..like it wants to spit the key out of ignition. I ended up driving it without using the clutch Just waiting for the right rpms and shifting..I dont even think its clutch related.I think something is installed incorrectly..like most recently the ignition coil..Any thoughts on this would be amazingly helpful
well the ignition coil is nowhere near ure blower motor,lines or anything.. it just siting right next to ure egr valve.. so thats probably just coinsidence that other things went wrong.
