94 prelude ideling trouble shooting
Old Nov 29, 2012 | 06:35 PM
94Prelude94's Avatar
Default 94 prelude ideling trouble shooting
I am new to this web site and just recently picked up a 94 honda prelude s. which has a 2.2 f22a1 sohc. however it does not idle at a consistant rpm. the rpms flucuate anywher from 2000-500 rpms and im not sure what would cause the motor to surge in such a way. i have replaced plugs and tps sensor. also has terrible throttle response and acceleration like no power. is running on all 4 cylinders. i was just curious if anyone else has had this problem and what are a few possible soultions.
Old Nov 29, 2012 | 11:39 PM
Alder's Avatar
Default Re: 94 prelude ideling trouble shooting
try to check the coolant level first and if it is low on coolant youll have a surging idle. If coolant is ok then the IACV on the throttle body is dirty or faulty
Old Nov 30, 2012 | 06:21 AM
i have cleaned the throttle body and still same thing. the coolant is where it should be. but i will check the iacv valve. thanks for the ideas
bmxfelon420
Mar 20, 2010 04:11 PM
ludemach23
Oct 10, 2009 09:42 AM
vtecnorb
May 24, 2009 04:33 PM
Blue94preludeSi
Jun 15, 2008 06:39 PM
dem0nk1d
14
Mar 22, 2006 05:57 PM
