B series engine guru's, click here.
Well, right now I have an OBD0 b16A block with stock PR3 pistons. Low miles. The head is an ITR head with some aftermarket port and polishing with ported intake manifold ports, dual valve springs and tit. retainers. Using a CTR intake cam and a B17 GSR Exhaust cam. Usdm ITR intake manifold thats been port matched to the head and bored @ the throttlebody. Motor runs great. Makes power all the way to 9k. I want a little bit more though, so im thinking about buying a GSR longblock soon and possibly swapping my ITR head over to the GSR block.
I know the GSR head has smaller combusion chambers which yelids higher compression, but the ITR head flows better. Being that im using the CTR intake cam, which setup do you guys think is best? I could put my cams in the GSR motor, or swap the ITR head onto the GSR block? Also, car is obd1 using a chipped p28
Swap the head and sell the B16 block with a gsr head. jumping from 1.6 to a 1.8 should be your primary reason for picking up a GSR block.
if your just picking up a short block forget what i said about selling the B16 block w/GSR head.
If is a better idea to put the ITR head on the GSR block, then i'll do that and put the GSR head on the b16 block and put it in my daily.
Yea, i can only get a longblock.Right now im using a cable LSD b16 trans, ill transfer it to the gsr block with the b16 head and get an LS trans for my daily.
the OP said that GSR head had smaller Comb. Chamber. Since the Quench pad is smaller, no argument there...the chamber would be smaller as well wen compared to an itr/b16 head. How are his facts mixed up?
Ive kinda decided to keep the 1.6 block because I have like 3 extra b16 blocks and if anything ever happen, it would be an easy fix.
