Transmission & Drivetrain Gearboxes, Differentials, Clutches
Sticky Clutch Pedal.. HELP PLS!!!
Old Nov 29, 2012 | 11:29 AM
Chemi421's Avatar
Default Sticky Clutch Pedal.. HELP PLS!!!
Hi Guys,
I have a 1997 del sol with a b18b1 and a new (1-yr old) Competition Clutch Stage 2. Sometimes when I push the clutch pedal ALL the way down to the ground, it just gets STUCK there or sometimes when I push the pedal down 75%, it will just kind of stick there or come up just a tiny bit!! This has been a huge problem for me lately and cannot figure out what the problem is!! =[
The clutch was just put in a year ago so I don't think thats the problem. Do you think I should bleed the master clucth cylinder?? Has this happened to anyone else?? Your help/input is GREATLY APPRECIATED!!
Thank you all so much!!
-Frustrated as heck :/
Old Nov 30, 2012 | 04:58 AM
Chemi421's Avatar
Default Re: Sticky Clutch Pedal.. HELP PLS!!!
No help??? (
Old Dec 1, 2012 | 09:26 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Yes bleed and have someone push pedal in and out and look and make sure slave is moving the release bearing fork about an inch.
Old Dec 5, 2012 | 07:44 AM
Chemi421's Avatar
Awesome.. Thank you so much for your input!!! )
Old Dec 6, 2012 | 01:09 PM
Chemi421's Avatar
I have a dumb question: so i checked the clutch fluid and it was a tad low.. Not sure if it was at or below the "minimum" level, but definitely below the "max" level... I have added clutch fluid so that it is at the "max" level now and the pedal doesnt stick anymore.
Could it be that my clutch fluid was a bit low to cause my pedal to stick like that????
Thanks!!!
asselinma
Apr 17, 2012 08:31 PM
integragsssr
Feb 6, 2009 08:54 PM
Si93_22
Oct 29, 2007 08:59 AM
blkgsr03
14
Sep 16, 2004 05:19 AM
gsr camel
Sep 13, 2001 12:05 PM
