f22a or h22a into an EF chassis.
Old Oct 18, 2002 | 08:33 PM
BudaKai's Avatar
Default f22a or h22a into an EF chassis.
Anyone done this? If so how much did it cost, and how hard was it? Yes I've search but I want an opinion from you.
Old Oct 19, 2002 | 01:13 AM
ninjaMONKEY
Guest
Posts: n/a
Default Re: f22a or h22a into an EF chassis. (tzsir)
first off
can you weld?
do you know or have access to the wiring of both the ef chassis and a h -series motor
you need to move the fire wall back about 6-8 inches to clear the h-series motor. as well as reinforcing the engine bay after cutting alot of it out is also necessary. if its your first swap think b-series. they are designed for that chassis
late
Old Oct 19, 2002 | 04:30 PM
Jonathan_ED3's Avatar
Default Re: f22a or h22a into an EF chassis. (civeg)
move the firewall back 6-8"?
Where did you get that info? Maybe if you're making your own mounts.
Check out the Place Racing mounts bro.
Old Oct 19, 2002 | 05:20 PM
ExospeedAMcrx's Avatar
Jeremy's L'NAtural race crx has the H22 in it. no cutting of the firewall needed.
Old Oct 19, 2002 | 05:36 PM
spettinger's Avatar
Default Re: f22a or h22a into an EF chassis. (exospeedAMcrx)
yep, no firewall cutting, even with some monster individual throttle bodies. saw his civic up close and said
maxwellmercer
Mar 20, 2010 07:04 AM
akouznet
Nov 12, 2008 10:57 PM
josholio
Jun 23, 2005 11:53 PM
Corporation
Aug 21, 2004 11:05 AM
mattduskater
29
Nov 10, 2003 07:15 AM
