civic cluster dont work!!!!!! rpm and mph?????
when my MPH wasn't working, it was because my VSS was a bit loose.
but yours sounds a bit more like a problem on the cluster side. you have any friends you could swap theirs in real quick to check?
Sounds WAYY out in left field, but check your fuses? i believe there is a fuse that goes to your cluster(Correct me if i'm wrong, something in that genre), also double check all the wiring, switch out the wiring if you can. Good excuse to get a brand new cluster too.
nomoreavril
10
Dec 11, 2006 04:02 PM
EK SQUAD 425
May 10, 2006 03:28 AM
G2turbo_terror
Feb 23, 2003 09:57 PM
