chipped p75 ecu running b16 no vtec?
Old Nov 28, 2012 | 11:32 AM
camtoe420's Avatar
Default chipped p75 ecu running b16 no vtec?
so i have obd0 b16a vtec engine converted to obd1. it used to run mint, vtec worked perfect. but i fried my ecu because there was tinfoil in the ecu fuse, ne ways i bought a so called "chipped p28" of ebay...it ended up being a chipped p75. i brought that into a few different shops around town, and put a b16 map on it, but theres no friggin vtec action.. SO my question is will a p75 actually run a b16? because i no its actually from a non vtec integra...also the car idles insanely low...any help would be awsome!
Old Nov 28, 2012 | 11:33 AM
camtoe420's Avatar
Default Re: chipped p75 ecu running b16 no vtec?
also when i remove the chip and put it in my p06 ecu, i get the same results NO VTEC
Old Nov 28, 2012 | 06:47 PM
mtber's Avatar
A p75 and a p06 ecu are non-vtec ecus.
Vtec hardware must be added to the ecus for them to work with a vtec engine.
You must also have the proper vtec tune on your 28 pin eprom chip.
You should also make sure you are throwing no malfunction indication codes.
em1gangsta
18
Mar 28, 2016 05:36 PM
smokey68321
May 26, 2010 09:20 AM
dizzyroc88
Southeast (Sales)
Jun 27, 2008 04:29 AM
Sean5826
Jun 18, 2008 10:17 AM
DOHC-V-TEC-DA
Feb 3, 2006 06:03 PM
